[mapserver-users] WMS Server and Custom ESPG code
Donald Kerr
donald.kerr at dkerr.co.uk
Fri Nov 1 12:28:58 PDT 2013
Brian,
My layers are in EPSG:27700 and I can successfully re-project to
EPSG:900913. I have the following set up:
In map file:
CONFIG "PROJ_LIB" "d:/mapserver/proj4"
PROJECTION
"init=epsg:27700"
END # PROJECTION
WEB
METADATA
# WMS
"wms_title" "WMS Title"
"wms_onlineresource"
"http://localhost/mapserver/mapserv.asp?"
"wms_srs" "EPSG:27700
EPSG:900913" #Additional projections do not need to be set in LAYER if set
here
"wms_enable_request" "*"
"wms_abstract" "Abstract"
"wms_extent" "0 0 670000
1230000"
"wms_feature_info_mime_type"
"text/plain"
"text/html"
"application/vnd.ogc.gml" # &info_format=application/vnd.ogc.gml
END # METADATA
END # WEB
In the layer:
METADATA
# WMS
"wms_title" "MyTitle"
"wms_extent" "0 0 670000 1230000"
"wms_srs" "epsg:27700"
END # METADATA
PROJECTION
"init=epsg:27700"
END # PROJECTION
Hopefully you can pick through the above to make yours work.
Regards,
Donald
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Brian Fischer
Sent: 01 November 2013 18:41
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] WMS Server and Custom ESPG code
I am trying to use MapServer 6.2.1 as a WMS server with a custom projection
and espg code, but I keep getting this error message.
msWMSLoadGetMapParams(): WMS server error. Invalid SRS given : SRS must be
valid for all requested layers.
Is this supported? I have followed these steps.
1) Defined the custom projection with a new espg code in
\ms4w\proj\nad\epsg
2) In the mapfile, I added the reference to the Proj (CONFIG "PROJ_LIB"
"E:/ms4w/proj/nad")
3) Defined the new espg in the Web, Projection, Layer objects of the
mapfile.
4) Verified the mapfile works using the shp2img utility
Has anyone else go this to work?
Thanks!
Brian
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20131101/7ee8e390/attachment.htm>
More information about the MapServer-users
