[mapserver-users] MapCache and a transparent layer
thomas bonfort
thomas.bonfort at gmail.com
Sun Nov 3 23:50:18 PST 2013
James,
If you're accessing mapcache through untiled WMS calls (which is
probably the case), then the format used by mapcache for returning
images is defined in the wms service block
(https://github.com/mapserver/mapcache/blob/branch-1-2/mapcache.xml.sample#L819
, https://github.com/mapserver/mapcache/blob/branch-1-2/mapcache.xml.sample#L855
). You can set it to jpeg if you are serving data with no
transparency, or png in your case.
thomas
On 2 November 2013 03:58, James_in_Utah <James.Evans at hill.af.mil> wrote:
> Hi,
> I'm trying to get mapchache working, and I have one layer that I can not
> figure out. I have a states boundaries layer, all vector data, and it works
> fine when reading from the WMS. I added it as a layer in my mapcache.xml,
> and I can not get it to be transparent. I've added
> <TRANSPARENT>true</TRANSPARENT> to the params in the source. If I look at
> the .png files that are stored in the cache, they appear to be transparent,
> but when my client tries to display the boundaries, they have a black
> background and obscure the other layers. If I look in the cache of my
> client, at the.dds files that it saves, they all have a black background.
> If I look at the.dds files the client saves when hitting the WMS directly,
> they appear to have a transparent background. Below are my source, and
> tileset from the mapcache.xml. Any help on this would be appreciated.
> Thanks!
> James
> <source name="RADESWMS States" type="wms">
> <http>
> <url>http://127.0.0.1/cgi-bin/radeswms.exe</url>
> </http>
> <getmap>
> <params>
> <FORMAT>image/png</FORMAT>
> <LAYERS>States</LAYERS>
> </params>
> </getmap>
> </source>
> <tileset name="States">
> <source>RADESWMS States</source>
> <cache>disk</cache>
> <format>PNG_FAST</format>
> <grid>WGS84</grid>
> </tileset>
> View this message in context: http://osgeo-org.1560.x6.nabble.com/MapCache-and-a-transparent-layer-tp5087059.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at lists.osgeo.org
