[mapserver-users] mapserver 6.4.0 can't create geom with postgis 2.1.0?!
Rahkonen Jukka
jukka.rahkonen at mmmtike.fi
Fri Nov 8 23:28:59 PST 2013
It is a warning. It should mean that everything still works. Or do you mean that you have run the
"psql -d [yourdatabase] -f legacy.sql" command in your database and that you can do from psql
SELECT ST_Force_2d with a good result but you can't get maps out of Mapserver because of this error?
If that is the situation, perhaps you have not installed legacy functions into your production database. It is a per database thing, it is not enough that you find the function from the disk.
-Jukka Rahkonen-
John Smith wrote:
> guys,
> looks like mapserver 6.4.0 can't create geom with postgis 2.1.0. can someone confirm that before i rollback to ms 6.2.1 or before :( is there any other solution?
> just trying to connect ms 6.4.0 with pg 2.1.0 but getting the following error:
> WARNING: ST_Force_2d signature was deprecated in 2.1.0. Please use ST_Force2D
> CONTEXT: SQL function "st_force_2d" during startup
> both functions exist under public > functions but ST_Force_2d creates this error while ST_Force2D is unused. see http://stackoverflow.com/questions/19000753/mapserver-6-2-and-deprecated-st-force-2d > https://github.com/mapserver/mapserver/pull/4803 (mappostgis.c, mappostgis.h) and http://postgis.net/docs/ST_Force_2D.html.
thks, jzs
