[mapserver-users] [OT] Problem loading php5-mapscript
Raffaele Morelli
raffaele.morelli at gmail.com
Tue Nov 12 03:55:11 PST 2013
2013/11/12 Lester Caine <lester at lsces.co.uk>
> Raffaele Morelli wrote:
>> I am wonder if any of you using debian (testing) with php5.5.5 installed
>> is
>> having problems in loading php_mapscript.so
>> No matter how I tried php error log always reports
>> PHP Startup: Unable to load dynamic library
>> '/usr/lib/php5/20121212/php_mapscript.so'
> It would be nice if PHP actually responded with more helpful failure
> messages.
> Starting point is ... has the php_mapscript.so file been rebuilt using
> 5.5.5?
> Brain is not as good as it used to be, but last time I had a problem here
> it was something to do with the dependencies that mapscript was looking for.
My local setup in quite the same, everything works fine and mapscript
dependencies are honoured, really can't figure out what's going on
> I've just moved over to using nginx and it's working fine but I know I
> added a couple of other packages previously
http://maptools.org/ms4w/ content list is probably worth a scan.
that's windows stuff, linux here :-)
/r
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20131112/c363603c/attachment.html>
