[mapserver-users] error with SQL query
Rahkonen Jukka
jukka.rahkonen at mmmtike.fi
Tue Nov 12 05:10:23 PST 2013
I am sure you will solve it by making a "simple" SQL query which works for you with your data and after that adding one piece at a time for making it more complex. At least you can then send youR next mail as "I had in my DATA 'this' and it worked but once I changed it to 'that' it stopped working. Why?"
Good luck,
-Jukka Rahkonen-
Luca Delucchi wrote:
> Hi all,
> I'm trying to use a "complex" SQL query on my layer but it return an error.
> My definition on the mapfile is
> grid_5x5.geom, grid_5x5.gid, count(occurrence.specie) AS count FROM
> (occurrence JOIN grid_5x5 ON (st_intersects(occurrence.wkb_geometry,
> grid_5x5.geom))) WHERE specie='ursarc' GROUP BY grid_5x5.gid as subquery
> USING UNIQUE grid_5x5.gid USING UNIQUE 25832
> and it works well on postgis.
> The error returned is
> msDrawMap(): Image handling error. Failed to draw layer named 'orsobruno'.
> msPostGISLayerWhichShapes(): Query error. Failed to build query SQL.
> msPostGISBuildSQL(): General error message. Failed to build SQL 'where'.
> Someone can help me?
> thanks
> ciao
> Luca
> http://gis.cri.fmach.it/delucchi/
> www.lucadelu.org
> mapserver-users at lists.osgeo.org
