[mapserver-users] Mapcache error proxy curl with external WMS
samuelmesa at gmail.com
Thu Nov 14 09:18:47 PST 2013
Thank you very much Thomas, is what I needed to set the MapCache demo.
Thank you for your prompt response,
Regards,
Samuel Mesa.
2013/11/14 thomas bonfort <thomas.bonfort at gmail.com>
> it's not settable in the mapcache.xml file, however you should be able
> to do it through your apache configuration file:
> http://httpd.apache.org/docs/2.2/mod/mod_env.html#setenv
> thomas
> On 14 November 2013 17:20, samuelmesa at gmail.com <samuelmesa at gmail.com>
> wrote:
> > Thanks for your answer Thomas. However I have requested the map directly
> > from OSGeo WMS and I have no problems, and likewise from the command
> > mapcache_seed. However from the Web demo MapCache can not display
> images, or
> > you can not generate the tiles due to the reported error with Curl and
> Web
> > proxy.
> > The truth know, but it is possible that I can configure the Web Proxy in
> > MapCache XML file?
> > Regards,
> > Samuel Mesa
> > 2013/11/12 thomas bonfort <thomas.bonfort at gmail.com>
> >> The osgeo vmap wms service seems to be down for the time being, so
> >> with or without a proxy you won't be able to get anything other than
> >> an error.
> >> cheers,
> >> thomas
> >> On 12 November 2013 18:35, samuelmesa at gmail.com <samuelmesa at gmail.com>
> >> wrote:
> >> > Hello, I get errors when trying to connect to a WMS through a proxy
> >> > server.
> >> > I get the following error:
> >> > curl failed to request url
> http://vmap0.tiles.osgeo.org/wms/vmap0?VERSION=1.1.1&REQUEST=GetMap&SERVICE=WMS&STYLES=&BBOX=-187.031250,-97.031250,187.031250,97.031250&WIDTH=532&HEIGHT=276&FORMAT=image/png&SRS=EPSG:4326&LAYERS=basic
> >> > : Failed connect to vmap0.tiles.osgeo.org:80; Operation now in
> progress
> >> > In Archlinux I have configured the global environment variables
> >> > http_proxy
> >> > and have not obtained the expected results.
> >> > Thanks for any help.
> >> > Regards,
> >> > Samuel Mesa
> >> > / v \
> >> > _______________________________________________
> >> > mapserver-users mailing list
> >> > mapserver-users at lists.osgeo.org
> >> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
> > / v \
/ v \
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20131114/6e2d4cf9/attachment.html>
