[mapserver-users] GetCapabilities always returning version 1.3.0
Rahkonen Jukka
jukka.rahkonen at mmmtike.fi
Thu Nov 14 15:23:23 PST 2013
WMS standard says about version number negotiation
"A WMS client may negotiate with a server to determine a mutually agreeable
protocol version. Negotiation isperformed using the GetCapabilities
operation (described in 7.2) according to the following rules.
All service metadata shall include a protocol version
number and shall comply with the XML DTD or Schema
defined for that version. In response to a GetCapabilities request
(for which the VERSION parameter is optional)that does not specify a
version number, the server shall respond with the highest version it supports.
In responseto a GetCapabilities request containing a version number
that the server implements, the server shall send that
version. If the server does not support the requested version, the server shall respond
with output that conforms
to a version it does support, as determined by the following rules:
- If a version unknown to the server and higher than the lowest supported version
is requested, the server shallsend the highest version it supports that
is less than the requested version.
- If a version lower than any of those known to the server is requested,
then the server shall send the lowest version it supports.
- If the client does not support the version sent by theserver, it may either
cease communicating with the server or send a new request with a different
version number that the client does support
Thus, you ask GetCapabilities without version and you get the highest supported (1.3) and so far everything is all right. But I wonder why people want to drop version out of the request because it really tends to make more trouble thatn good.
Next thing is that you have misunderstood the meaning of "wmw_server_version". It is used when Mapserver reads data from another WMS server (cascading WMS). There is another metadata item for controlling the version that Mapserver writes into the GetCapabilities and it is "wms_getcapabilities_version" as you can read from http://mapserver.org/ogc/wms_server.html
But I do not understand one thing: why doesn't your GetMap in WMS 1.3.0 work. It should, and it does work for me with MS 6.2.1 even I added that faulty metadata item "wms_server_version" "1.1.1" just like you.
-Jukka Rahkonen-
Sowmya Tiramdasu wrote:
I have mapserver configured on my IIS server. I configured a project on it . My mapfile looks like this :
MAP
IMAGETYPE PNG
EXTENT -87.041564905451 34.41840442792049 85.87371108337896 35.01821204159302 # extents in GoogleEarth 4326 projection.
SIZE 1000 800
SHAPEPATH "C:\data"
SYMBOLSET "../symbols/symbols35.sym"
TRANSPARENT ON
CONFIG "PROJ_LIB" "../proj/nad"
IMAGECOLOR 0 0 0
FONTSET "../fonts/fonts.list"
PROJECTION
"init=epsg:4326"
END
WEB
IMAGEPATH "C:/inetpub/wwwroot/Images/"
IMAGEURL "http://localhost/Images/"
METADATA
"wms_enable_request" "*"
"wms_title" "WMS Lidar Server"
"wms_onlineresource" "http://SOWMYAPC/Mapserver/mapserv.exe?map=Map/Madison.map&"
"wms_srs" "epsg:4326"
END
END
CONFIG "CPL_DEBUG" "ON"
CONFIG "PROJ_DEBUG" "ON"
LAYER
NAME "MadisonBoundariesDefault"
TYPE RASTER
STATUS ON
CONNECTION "http://localhost/Sheridan/Default.aspx?PROJECT=Madison"
CONNECTIONTYPE WMS
#OPACITY 50
METADATA
"wms_srs" "EPSG:4326 EPSG:26916 "
"wms_name" "Boundaries"
"wms_format" "image/png"
"wms_style" "Default"
"wms_exceptions_format" "application/vnd.ogc.se_xml"
"wms_latlonboundingbox" "-87.041564905451 34.41840442792049 85.87371108337896 35.01821204159302"
"wms_extent" "5110296.9 557718.4 5122127.3 562697.3 "
"wms_width" "1024"
"wms_height" "1024"
END
DEBUG 5
END
END.
Now, when I do a get capabilities call on this, This is what I get:
http://localhost/Mapserver/mapserv.exe?map=Map/Madison.map&SERVICE=WMS&REQUEST=GetCapabilities
<?xml version="1.0" encoding="ISO-8859-1"?>
<WMS_Capabilities xsi:schemaLocation="http://www.opengis.net/wms http://schemas.opengis.net/wms/1.3.0/capabilities_1_3_0.xsd http://www.opengis.net/sld http://schemas.opengis.net/sld/1.1.0/sld_capabilities.xsd http://mapserver.gis.umn.edu/mapserver http://SOWMYAPC/Mapserver/mapserv.exe?map=Map/Madison.map&service=WMS&version=1.3.0&request=GetSchemaExtension" xmlns:ms="http://mapserver.gis.umn.edu/mapserver" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:sld="http://www.opengis.net/sld" xmlns="http://www.opengis.net/wms" version="1.3.0"><http://localhost/Mapserver/mapserv.exe?map=Map/Madison.map&SERVICE=WMS&REQUEST=GetCapabilities>
<!-- MapServer version 6.2.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=PDF OUTPUT=KML SUPPORTS=PROJ SUPPORTS=GD SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=CAIRO SUPPORTS=OPENGL SUPPORTS=ICONV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS SUPPORTS=GEOS INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE -->
<Service><http://localhost/Mapserver/mapserv.exe?map=Map/Madison.map&SERVICE=WMS&REQUEST=GetCapabilities><Name>WMS</Name>
<OnlineResource xlink:href="http
I see that the version is coming up as 1.3.0. From where is this version number coming ? I thought in my mapfile, I gave the "wms_server_version" "1.1.1". I do not understand from where 1.3.0 is coming.
Whereas , if I make a getCapabilities call with the following URL ,
http://localhost/Mapserver/mapserv.exe?map=Map/Madison.map&SERVICE=WMS&REQUEST=GetCapabilities&VERSION=1.1.1
I get the below xml with version 1.1.1.
<?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
<!DOCTYPE WMT_MS_Capabilities SYSTEM "http://schemas.opengis.net/wms/1.1.1/WMS_MS_Capabilities.dtd"
<!ELEMENT VendorSpecificCapabilities EMPTY>
]> <!-- end of DOCTYPE declaration -->
<WMT_MS_Capabilities version="1.1.1">
I am confused what is my actual WMS version. Any help would be greatly appreciated.
PS: when I do a getMap request in 1.1.1 version specifications , it works fine. But when I try to do a call in 1.3.0 specification I get the following error : “msBuildWMSLayerURL(): WMS connection error. MapServer supports only WMS 1.0.0 to 1.1.1 (please verify the VERSION parameter in the connection string).”
Thanks,
Sowmya Tiramdasu
QCoherent Software
9668 Madison Blvd., Suite 202
Madison, AL 35758
(256) 461-8289 Telephone
(256) 461-8249 Fax
www.geocue.com<http://www.geocue.com/>
More information about the MapServer-users
