[mapserver-users] Some trouble with mapserver-trunk and FEATURE elements
Andrea Peri
aperi2007 at gmail.com
Tue Oct 1 04:56:00 PDT 2013
I resolve the problem.
It was not in the FEATURE.
But instead in the CLASS where I have 2 label defined in the same class (to
have distinct scale interval).
This was accepted from previous mapserver the last trunk refuse this.
I *split the two label in two distinct class and all restart to work.
*Sorry for noise.
2013/10/1 Andrea Peri <aperi2007 at gmail.com>
> Hi,
> testing the last map-server trunk I see there is an error.
> The code is this:
> TYPE LINE
> TRANSFORM LL
> UNITS percentages
> FEATURE
> POINTS 0.02 -0.40 0.98 -0.40 END
> TEXT 'blah blah'
> END
> FEATURE
> POINTS 0.02 -0.60 0.98 -0.60 END
> TEXT 'blah2 blah2'
> END
> without this piece of code the map was correctly produce.
> With this the result is an error.
> But This code work without apparently any error before.
> I try also to remove a feature:
> TYPE LINE
> TRANSFORM LL
> UNITS percentages
> FEATURE
> TEXT 'blah blah'
> END
> But still the error is here.
> Any hint ?
> Andrea Peri
> qwerty àèìòù
Andrea Peri
qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20131001/3ec6b095/attachment.html>
