[mapserver-users] Any thoughts on combining 3 regional maps into one?
Stephen Woodbridge
woodbri at swoodbridge.com
Wed Oct 2 08:52:51 PDT 2013
Hi all,
I have 3 regional mapfiles for US, Canada and Mexico and I want to
create a single North America map. Since the data comes from separate
vendors and they refresh on different cycles, I'm trying to figure out
the best way to structure this in a mapfile. I also need to maintain
each region as a separate mapfile. (I'm ignoring issues like data
alignment over borders.)
The reginal mapfile data is structure like:
.../us/data/<shapefiles>
.../us/us.map
.../mx/data/<shapefiles>
.../mx/mx.map
.../ca/data/<shapefiles>
.../ca/ca.map
The shapepath for each mapfile is set to the local data directory. What
I would like to avoid is having to change all the paths in the mapfiles
to accomodate a change like:
.../na/us/data/
.../na/mx/data/
.../na/ca/data/
.../na/na.map
It would be cool if I can change the shapepath in the middle of the
mapfile so layers beyond the change would use the new shapepath, but I
suspect that will not work.
So it looks like my options are:
1. rewrite all the mapfile data pathes as I combine them into one new
mapfile and maintain two copies, regional and na versions.
2. maybe create a new mapfile that loads each of the regions as a WMS
client and overlays the adjacent regions. This will get served via
mapcache so that might add some options for tile assembly.
3. other ideas????
Thanks,
-Steve
