[mapserver-users] [EXTERNAL] Any thoughts on combining 3 regional maps into one?
Smith, Michael ERDC-RDE-CRREL-NH
Michael.Smith at erdc.dren.mil
Wed Oct 2 10:12:25 PDT 2013
Steve,
You can also do some kind of preprocessing. Generate your mapfile from a
script. The Scribe syntax may be quite useful for you
(http://www.mapgears.com/en/blog/archive/2013-03-12-scribe and
https://github.com/solutionsmapgears/Scribe). Then just run the scribe
python script and you can regenerate your mapfiles from the multiple ones
and use things like variables.
Mike
Michael Smith
US Army Corps
Remote Sensing GIS/Center
On 10/2/13 11:52 AM, "Stephen Woodbridge" <woodbri at swoodbridge.com> wrote:
>Hi all,
>I have 3 regional mapfiles for US, Canada and Mexico and I want to
>create a single North America map. Since the data comes from separate
>vendors and they refresh on different cycles, I'm trying to figure out
>the best way to structure this in a mapfile. I also need to maintain
>each region as a separate mapfile. (I'm ignoring issues like data
>alignment over borders.)
>The reginal mapfile data is structure like:
>.../us/data/<shapefiles>
>.../us/us.map
>.../mx/data/<shapefiles>
>.../mx/mx.map
>.../ca/data/<shapefiles>
>.../ca/ca.map
>The shapepath for each mapfile is set to the local data directory. What
>I would like to avoid is having to change all the paths in the mapfiles
>to accomodate a change like:
>.../na/us/data/
>.../na/mx/data/
>.../na/ca/data/
>.../na/na.map
>It would be cool if I can change the shapepath in the middle of the
>mapfile so layers beyond the change would use the new shapepath, but I
>suspect that will not work.
>So it looks like my options are:
>1. rewrite all the mapfile data pathes as I combine them into one new
>mapfile and maintain two copies, regional and na versions.
>2. maybe create a new mapfile that loads each of the regions as a WMS
>client and overlays the adjacent regions. This will get served via
>mapcache so that might add some options for tile assembly.
>3. other ideas????
>Thanks,
> -Steve
>_______________________________________________
>mapserver-users mailing list
>mapserver-users at lists.osgeo.org
>http://lists.osgeo.org/mailman/listinfo/mapserver-users
