[mapserver-users] MapCache disk cache issue
thomas bonfort
thomas.bonfort at gmail.com
Thu Oct 3 03:50:38 PDT 2013
post the full <cache> element. you should be using the
layout="template" attribute
On 3 October 2013 10:10, Eric Sonaron <eric.sonaron at gmail.com> wrote:
> Hi,
> I'm using MapCache with a disk cache configuring using a template similar
> than:
> <template>/tmp/template-test/{tileset}#{grid}#{dim}/{z}/{x}/{y}.{ext}</template>
> Problem is on disc, a folder structure is created putin 000 folders for Z,
> X, Y.
> Is there a way to avoid MapCache creates de 000 folders?
> Thanks.
> mapserver-users at lists.osgeo.org
