[mapserver-users] MapCache 1.2.0 and NGNIX 1.5 problem
thomas bonfort
thomas.bonfort at gmail.com
Fri Oct 4 01:00:40 PDT 2013
You might want to check the spawn-fcgi logs. Note that there is no
place in the mapcache code that emits a 403 error, i.e. that 403 is
coming from something else than mapcache.
thomas
On 4 October 2013 09:38, Pascual Ayats, Victor <victor.pascual at icc.cat> wrote:
> Hi users,
> I compiled and installed MapServer 6.4 and MapCache 1.2 as fastcgi in a
> Linux Red Hat 6 (64 bits)
> I compiled NGNIX 1.5 (adding MapCache as a module) and installed fcgiwarp
> and spanw-fcgi in order to run fastcgi in NGNIX.
> MapServer works very well and fast but I have a problem dealing with
> MapCache. MapCahce works well in GetCapbilities requests or when already
> existing tiles in the file system pre generated by mapcacahe_seed , but when
> I send a request and the tile not exist then I received a “403 Forbbiden”
> error.
> So MapCache “fails” when try to generate a tile on the fly.
> The 403 Forbbiden error not comes from NGINX (not appear in error log), so
> it seems that the error comesfrom the spanw-cgi process or Mapcahe .fcgi??
> I have no idea what might happen and who to solve it
> Here’s the spanw-fcgi config
> FCGI_SOCKET=/var/run/fcgiwrap.socket
> FCGI_PROGRAM=/usr/local/sbin/fcgiwrap
> FCGI_USER=nginx
> FCGI_GROUP=nginx
> FCGI_EXTRA_OPTIONS="-M 0777"
> OPTIONS="-u $FCGI_USER -g $FCGI_GROUP -s $FCGI_SOCKET -S $FCGI_EXTRA_OPTIONS
> -F 1 -P /var/run/spawn-fcgi.pid -- $FCGI_PROGRAM"
> Here’s the nginx .conf
> #Mapserver
> location /maps/ {
> fastcgi_pass unix:/var/run/fcgiwrap.socket;
> include fastcgi_params;
> fastcgi_param SCRIPT_FILENAME $document_root$fastcgi_script_name;
> #Mapcache
> location ~ ^/mapcache(?<path_info>/.*|$) {
> set $url_prefix "/mapcache";
> mapcache /opt/geo/data/mapcache/mapcache.xml;
> error_page 404 = @fcgi_mapcache;
> #MapCache 404
> location @fcgi_mapcache {
> Any help will be greatly appreciated
> Best regards
> Victor Pascual Ayats
> mapserver-users at lists.osgeo.org
