[mapserver-users] preparing orthos for Mapserver?
Rahkonen Jukka
jukka.rahkonen at mmmtike.fi
Sun Oct 6 03:02:12 PDT 2013
So the amazing file size of that GIS editor software is 600 kB or 601088 bytes to be exact.
-Jukka-
________________________________________
Rahkonen Jukka wrote:
Andrea Aime wrote:
> Hi Frank,
> this is quite interesting. Can you elaborate a bit of what "one block scanline" means?
> E.g., what is the actual tiling structure of this file?
> Does presence of compression affect the ability to do the subsampling?
> How about quality of the output? (e.g., is GDAL reading one pixel every N to generate
> the reduced resolution version?)
One scanline blocks can be created by using GeoTIFF creation option BLOCKYSIZE.
For example
gdal_translate -of GTiff -co blockysize=1 -outsize 1000 1000 test_in.TIF test_out.tif
gdalinfo test_out.tif
Band 1 Block=1000x1 Type=Byte, ColorInterp=Red
Band 2 Block=1000x1 Type=Byte, ColorInterp=Green
Band 3 Block=1000x1 Type=Byte, ColorInterp=Blue
I can't tell about usability for compressed images and quality of subsampling without making some tests.
I could not refresh my memory with the GIS editing software I mentioned by trying if it really is so speedy. I did find program which is one single .exe file with an amazing file size of 600 MB but it appeared to be a 16-bit Windows program and I could not run it with my current computer. I remember that we did use both tiff files and Erdas LAN format which is probably something as simple to read as BIL and tiffs with one scanline per block are.
-Jukka Rahkonen-
Cheers
Andrea
Our support, Your Success! Visit http://opensdi.geo-solutions.it for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions S.A.S.
Via Poggio alle Viti 1187
55054 Massarosa (LU)
Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 339 8844549
http://www.geo-solutions.it
mapserver-users mailing list
mapserver-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapserver-users
