[mapserver-users] JPEGSetupDecode: Assertion failed
thomas bonfort
thomas.bonfort at gmail.com
Fri Oct 11 09:16:15 PDT 2013
Rich,
I believe this is gdal related, not mapserver.
regards,
thomas
On 11 October 2013 03:25, Richard Greenwood <richard.greenwood at gmail.com> wrote:
> I think I've botched up my linking on a MapServer 6.2 build but I'm not
> knowledgeable enough to see what I've done wrong. On Ubuntu 12.04 I built
> gdal 1.10 from source and it seems to work. I then built MapServer 6.2 from
> source and it works fine with vector data sources but raster data sources
> fail with:
> tif_jpeg.c:961: JPEGSetupDecode: Assertion `sp->cinfo.comm.is_decompressor'
> failed
> My MapServer configure statement:
> export LD_RUN_PATH=/usr/local/lib
> ./configure --with-gd
> --with-proj
> --with-postgis
> --with-geos
> --with-ogr=/usr/local/bin/gdal-config
> --with-gdal=/usr/local/bin/gdal-config
> --with-wfs
> --with-php=yes
> This machine also has libgdal on it from a QGIS install.
> Any suggestions or hits are appreciated.
> Thanks,
> Rich
> Richard Greenwood
> www.greenwoodmap.com
> mapserver-users at lists.osgeo.org
