[mapserver-users] font OUTLINE not working for all fonts in 6.2.0
thomas bonfort
thomas.bonfort at gmail.com
Fri Oct 18 02:50:26 PDT 2013
Charlton,
I was going to reply that the agg font outliner does not play well
with glyphs that contain invalid glyphs (e.g self-intersections,
duplicate control-points, etc...). However I've tested that glyph on a
simple test mapfile and the outlining works flawlessly (c.f. attached
image). I did test with 6.4 and not 6.2, but I do not believe there
are any differences between these two versions for this particular
testcase. Maybe you can try with 6.4?
thomas
On 17 October 2013 22:43, Charlton Galvarino <charlton at 2creek.com> wrote:
> I got around this by drawing my own simple SYMBOL triangle. But the mystery
> still remains!
> From: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Charlton
> Galvarino
> Sent: Thursday, October 17, 2013 3:43 PM
> To: Mapserver Users (mapserver-users at lists.osgeo.org)
> Subject: [mapserver-users] font OUTLINE not working for all fonts in 6.2.0
> Hi, all.
> If I take the simple example like the one from the docs,
> LABEL
> COLOR 150 150 150
> OUTLINECOLOR 0 0 0
> FONT "arial"
> TYPE truetype
> SIZE 6
> POSITION AUTO
> PARTIALS FALSE
> END
> I see a nice outline. But if I change the FONT to what I really want
> (esri_cart), I don’t see my outline anymore
> (http://www.fonts2u.com/esri-cartography.font). I do see the symbol drawn
> in 150 150 150, though.
> My MS production environment is 5.6.1, but I’m testing 6.2.0 now. Better
> late than never. In any case, this particular font outlined just fine in
> 5.6.1 but not here in 6.2.0, and I don’t know truetypes enough to know what
> the issue might be.
> And here’s the real kicker: I am after the arrowhead in the attachment
> (#182). If I change my text to be #180, I *do* see the outline in 6.2.0.
> So what is special about this bad boy?
> TIA.
> MapServer version 6.2.0 OUTPUT=PNG OUTPUT=JPEG SUPPORTS=PROJ SUPPORTS=AGG
> SUPPORTS=FREETYPE SUPPORTS=ICONV SUPPORTS=WMS_SERVER SUPPORTS=GEOS
> INPUT=JPEG INPUT=SHAPEFILE
> Charlton Galvarino
> 1 (803) 233-6205 : voice
> 1 (803) 223-9579 : fax
> P.O. Box 50960
> Columbia, SC 29250
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20131018/c91e95a3/attachment.obj>
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20131018/c91e95a3/attachment-0001.obj>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20131018/c91e95a3/attachment.png>
