[mapserver-users] Parsing error on click.
Stefanos Anastasiou
emperor_stef at yahoo.gr
Tue Oct 22 10:44:25 PDT 2013
Hello fellows!!
I'm quite new to mapserver and I'm still trying simple examples. I'm having a .html template and a .map file. My template is located in /usr/local/apache2/htdocs folder and my .map file is located in /home/mapdata folder.
The template is:
<!-- MapServer Template -->
<html>
<head><title>MapServer attempt</title></head>
<body>
<form method=POST action="/cgi-bin/mapserv">
<input type="submit" value="Click here">
<input type="hidden" name="map" value="/home/mapdata/hello.map">
<input type="hidden" name="map_web" value="/usr/local/apache2/htdocs/tmp">
</form>
<IMG SRC="[img]" width=400 height=300 border=0>
</body>
</html>
and the .map file is as follows:
MAP
Name "Attempt"
SIZE 400 300
IMAGECOLOR 249 245 186
IMAGETYPE png
EXTENT -1.00 -1.00 1.00 1.00
WEB
TEMPLATE "/usr/local/apache2/htdocs/hello.html"
IMAGEPATH "/usr/local/apache2/htdocs/tmp"
IMAGEURL "/tmp/"
END
LAYER
STATUS default
TYPE point
FEATURE
POINTS 0.0 0.0 END
TEXT "Hello World"
END
CLASS
STYLE
COLOR 255 0 0
END
LABEL
TYPE bitmap
END
END
END
END
When I load my template on the browser and I click on the button I get an error that says : loadWeb(): Unknown identifier. Parsing error near (/usr/local/apache2/htdocs/tmp):(line 1)
The mapfile seems OK simply because if I load it by itself (meaning: http://127.0.0.1/cgi-bin/mapserv?map=/home/mapdata/hello.map&mode=map) it displays what it's supposed to.
So the problem seems to be in the cgi about not passing the parameters to mapserver. I googled a lot but haven't found any answer yet applicable yet.
Any suggestion ?
Thanks in advance!!!
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20131022/fa7661f9/attachment.html>
