[mapserver-users] Can't remove artifacts aroung polygons with Mapserver 6.0.3
efujioka
efujioka at DUKE.EDU
Thu Oct 24 09:40:15 PDT 2013
Through further trials and errors, I found dropping SYMBOL parameter from the
polygon STYLE improves the image (artifacts less obvious). I should have
noticed this before...
Anyway, I still see slight artifacts and the tile image is less crisp than
5.2 due to anti-alias that you can't turn off??
An ideal solution would be to allow to turn off anti-alias for AGG/PNG with
RGBA, I guess. As I said before, GD/PNG with PC256 works fine (get an image
as crisp as with 5.2 [GD/PNG with RGBA] without artifacts) but it can't make
the layer transparent. So I think I'm stuck.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Can-t-remove-artifacts-aroung-polygons-with-Mapserver-6-0-3-tp5085423p5085623.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
