[mapserver-users] About a sentence in MapServer (fantastic) documentation
Havard Tveite
havard.tveite at umb.no
Mon Oct 28 03:05:56 PDT 2013
Hi Andrea,
I have updated the documentation (also for templatepattern).
Thank you so much for helping us improve the documentation!
If you are a github user, it is also possible to use github
for reporting issues with the documentation
(github.com/mapserver/docs).
Håvard
On 10/26/2013 10:01 AM, aborruso wrote:
> Hi all,
> yesterday I have worked on a mapfile. I needed to do run-time calls to this
> mapfile, to chane map file parameters via a form or a URL.
> I wanted to change DATA parameters via URL, and I set DATAPATTERN map
> parameter. In the documentation, for DATAPATTERN you have:
> "This defines a regular expression to be applied to requests to change DATA
> parameters via URL requests (i.e. map_layername_data=...)."
> Then I have started my web calls whit this kind of URL:
> http://myserver/cgi-bin/mapserv?map=/temp/test.map&mode=map&map_layername_data=012.tif
> But it does not work. I had to use:
> http://myserver/cgi-bin/mapserv?map=/temp/test.map&mode=map&map.layer[layername]=DATA+012.tif
> What do you think to modify the above documentation sentence in something
> like:
> parameters via URL requests (i.e. map.layer[layername]=DATA+...)."
> Best regards,
> Andrea
> View this message in context: http://osgeo-org.1560.x6.nabble.com/About-a-sentence-in-MapServer-fantastic-documentation-tp5085900.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at lists.osgeo.org
Håvard Tveite
Department of Mathematical Sciences and Technology, UMB
Drøbakveien 31, POBox 5003, N-1432 Ås, NORWAY
Phone: +47 64965483 Fax: +47 64965401 http://www.umb.no/imt/
