[mapserver-users] FW: problem with INTERSECTS query from OpenLayers to mapserver
Fawcett, David (MNIT)
David.Fawcett at state.mn.us
Fri Sep 13 13:42:19 PDT 2013
From: Sally Buechel [mailto:swbuechel at comcast.net]
Sent: Friday, September 13, 2013 3:39 PM
To: Fawcett, David (MNIT)
Subject: RE: [mapserver-users] problem with INTERSECTS query from OpenLayers to mapserver
Here are the POST queries output by OpenLayers and the wfs part of the mapfile its using if that helps (am also interested in confirming just that this general concept works, that someone is actually doing it successfully):
Example of the POST request for a non-spatial query which works
<wfs:GetFeature xmlns:wfs="http://www.opengis.net/wfs" service="WFS" version="1.0.0" maxFeatures="50" xsi:schemaLocation="http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.0.0/WFS-transaction.xsd<http://www.opengis.net/wfs%20http:/schemas.opengis.net/wfs/1.0.0/WFS-transaction.xsd>" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<wfs:Query typeName="feature:mytable">
<ogc:Filter xmlns:ogc="http://www.opengis.net/ogc">
<ogc:And>
<ogc:PropertyIsLessThan>
<ogc:PropertyName>attr2</ogc:PropertyName>
<ogc:Literal>5</ogc:Literal>
</ogc:PropertyIsLessThan>
<ogc:PropertyIsEqualTo>
<ogc:PropertyName>attr3</ogc:PropertyName>
<ogc:Literal>78008</ogc:Literal>
</ogc:PropertyIsEqualTo>
</ogc:And>
</ogc:Filter>
</wfs:Query>
</wfs:GetFeature>
Example of the POST for the spatial INTERSECTS query which fails:
<ogc:And>
<ogc:Intersects>
<ogc:PropertyName>attr1</ogc:PropertyName>
<gml:Polygon xmlns:gml="http://www.opengis.net/gml" srsName="EPSG:4326">
<gml:outerBoundaryIs>
<gml:LinearRing>
<gml:coordinates decimal="." cs="," ts=" ">-166.8375,69.723751831055 -168.75,63.311251831055 -166.3875,60.273751831055 -160.3125,57.573751831055 -155.5875,59.036251831055 -153.5625,62.748751831055 -156.6,66.911251831055 -166.8375,69.723751831055</gml:coordinates>
</gml:LinearRing>
</gml:outerBoundaryIs>
</gml:Polygon>
</ogc:Intersects>
</ogc:And>
</ogc:Filter>
</wfs:Query>
</wfs:GetFeature>
Response from failed Spatial query:
<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
<html><head>
<title>500 Internal Server Error</title>
</head><body>
<h1>Internal Server Error</h1>
<p>The server encountered an internal error or
misconfiguration and was unable to complete
your request.</p>
<p>Please contact the server administrator,
root at localhost and inform them of the time the error occurred,
and anything you might have done that may have
caused the error.</p>
<p>More information about this error may be available
in the server error log.</p>
<hr>
<address>Apache Server at localhost Port 80</address>
</body></html>
Apache error log:
[Fri Sep 13 01:49:34 2013] [error] [client 127.0.0.1] Premature end of script headers: mapserv, referer: http://localhost/testol6_7w.html
WFS part of Mapfile (note this mapfile works using shp2img when a FILTER is added to it):
MAP
<clipped out part>
# Set up WFS layer for feeding data to OpenLayers front-end
LAYER
NAME "mytable"
TYPE Polygon
STATUS ON
DUMP true #added 8/13 can't remember if needed...
CONNECTIONTYPE postgis
CONNECTION "host='localhost' dbname='test' user='user1' port=5432"
PROCESSING "CLOSE_CONNECTION=DEFER"
# need geometry, doesn't work for geography trying to cast it
# this worked for mapserver
DATA "attr1 from mytable USING UNIQUE gid USING srid=4326"
METADATA
"wfs_title" "My_WFS"
"wfs_version" "1.0.0"
"wfs_extent" "-180.00 -89.99 180.00 89.99"
"gml_include_items" "all"
"gml_featureid" "gid"
"wfs_enable_request" "*"
END
CLASS
NAME 'Attr1'
STYLE
COLOR -1 -1 -1
OUTLINECOLOR 0 255 0
END
END # end attr1 class
PROJECTION
"init=epsg:4326"
END
END #query layer
END #end map
From: Fawcett, David (MNIT) [mailto:David.Fawcett at state.mn.us]
Sent: Friday, September 13, 2013 12:15 PM
To: Sally Buechel; mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
Sally,
To make it easier for people to help you figure this out, I would suggest including the request string produced by OpenLayers and your mapfile text.
David.
From: mapserver-users-bounces at lists.osgeo.org<mailto:mapserver-users-bounces at lists.osgeo.org> [mailto:mapserver-users-bounces at lists.osgeo.org]<mailto:[mailto:mapserver-users-bounces at lists.osgeo.org]> On Behalf Of Sally Buechel
Sent: Friday, September 13, 2013 1:54 PM
To: mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
Subject: [mapserver-users] problem with INTERSECTS query from OpenLayers to mapserver
Am hoping someone can help or at least point me in the right direction regarding a problem I'm having trying to send a spatial filter produced in OpenLayers to mapserver. What I'm trying to do is so basic, I'm sure that many have done this, yet I've been unsuccessful. I thought this would be easy. With much searching I have found similar questions, but nothing actually answering or showing a working example of this.
I'm using mapserver 6.2.1 and the current OpenLayers.js. I can run the wfs.map file using shp2img and get a valid response from mapserver, I can run non-spatial filters using my OpenLayers WFS call to mapserver. The POST request sent to mapserver with the spatial query looks fine, but I simply get the not very helpful "premature end of script headers : mapserv" in response. The spatial input is a hand-drawn polygon in OpenLayers and the intersection at the mapserver end is a postgis table containing a polygon field. The table is large, but a spatial restriction should always yield a manageable number of records. Without a spatial restriction in the filter, I've noticed that mapserver tried to load all the data, so have currently restricted it to 100 records for testing/debugging. I'm assuming once I get the spatial filter that this will restrict the number of records retrieved on the server side. I have some assumptions, but as I said I've not been able to find a working example of this online, maybe because its too simple and everyone but me has it working?
Should what I'm trying to do work or am I just beating my head against the wall? It doesn't seem that this should be so hard...
Sally
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130913/72e4a2b5/attachment-0001.html>
