[mapserver-users] problem with INTERSECTS query from OpenLayers to mapserver
Yves Jacolin
yves.jacolin at camptocamp.com
Sun Sep 15 01:03:26 PDT 2013
Le samedi 14 septembre 2013 15:06:09 Sally Buechel a écrit :
> Yves - you are right. I really should re-compile with debug mode on,
> especially if you think there will be useful info for this particular
> problem. I had some problems with my original compile so had been putting
> off doing that.
Sally,
You don't need to build MapServer, you can have a look to the MAP object
documentation page and search for DEBUG parameter:
MAP
DEBUG 4
CONFIG "MS_ERRORFILE" "/ms4w/tmp/ms_error.txt"
END
See also http://mapserver.org/fr/optimization/debugging.html
Y.
Responsable Formation et Support
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel (France) : +33 4 79 26 57 98
Tel (Suisse) : 021 619 10 43 (new)
Mob. : +33 6 18 75 42 21
Fax : 04 79 70 15 81
Mail : yves.jacolin at camptocamp.com
http://www.camptocamp.com
