[mapserver-users] TYPE/FONT/SIZE breaks labels
Fawcett, David (MNIT)
David.Fawcett at state.mn.us
Mon Sep 16 10:07:13 PDT 2013
You don't mention if you have a fontset file or an associated entry in your mapfile.
http://mapserver.org/mapfile/fontset.html
David.
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Michael McInnis
Sent: Monday, September 16, 2013 12:04 PM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] TYPE/FONT/SIZE breaks labels
Mapservers!
I have bailed on dynamically generating labels and fell back to a .map based solution and may have found the primary problem. If I enable TYPE or FONT or SIZE in the LABEL section my map fails to display. I installed Truetype fonts on my Ubuntu system on Friday.
Does anyone know why the fonts will not function?
LAYER
CONNECTIONTYPE POSTGIS
NAME airports
CONNECTION "host=xxxx dbname=xxxx user=xxxx password=xxxx port=xxxx"
PROCESSING "CLOSE_CONNECTION=DEFER"
#DATA "geom From airports"
DATA "geom From (select a.icao, geom From airports a left join airportdata e on a.icao = e.icao where e.icao Is Not Null) as subquery using unique icao using srid=4326"
STATUS ON
TYPE POINT
LABELITEM "icao"
CLASS
LABEL
#TYPE truetype
#FONT "sans"
#SIZE 8
ANTIALIAS TRUE
POSITION AUTO
PARTIALS TRUE
MINDISTANCE 100
BUFFER 4
COLOR 0 0 0
END
NAME "airportsClass"
STYLE
SYMBOL 'circle-filled'
SIZE 3
COLOR 255 22 22
END
END # Class
END # Layer
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130916/b5f24ddf/attachment.html>
