[mapserver-users] No points selected with queryByShape
Lime, Steve D (MNIT)
Steve.Lime at state.mn.us
Tue Sep 17 17:23:52 PDT 2013
A layer must be queryable and ON before you can run query operations on it. That is:
LAYER
NAME 'business_point_locations'
STATUS ON # or DEFAULT
TYPE POINT
TEMPLATE void
END
Steve
Sent: Tuesday, September 17, 2013 5:23 PM
To: Lime, Steve D (MNIT); mapserver-users at lists.osgeo.org
Subject: RE: [mapserver-users] No points selected with queryByShape
Not sure I follow this.
Template is an empty layer in my map file we use to add shapes to for display.
My Feature layer is a shapefile of business point locations.
What does queryable mean in relation to a shapefile of points?
Michael McInnis 6033 44th Ave. N.E. Seattle, WA 98115 206 517-4701
To: mmcinnis59 at msn.com; mapserver-users at lists.osgeo.org
Date: Tue, 17 Sep 2013 22:16:16 +0000
Is your feature layer queryable? That is, does is have a value set for TEMPLATE? Even ‘TEMPLATE void’ will do.
Steve
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Michael McInnis
Sent: Tuesday, September 17, 2013 4:51 PM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] No points selected with queryByShape
I'm baffled on this one!
I get a shape object $circle and I have a point layer $bizLayer.
I know they are both valid as they overlay as expected on my map.
When I call printBusiness to use queryByShape to get the points in the shape it always returns 0 for $numResults.
Am I missing a step somewhere?
// Get shape from point and radius
$circle = createCircle($latlonPoint,$radius);
echo 'Biz Count : ';
$bizCount = printBusiness($bizLayer,$circle);
echo $bizCount;
// Draw all the layers per basic1.map
$image=$map->draw();
// Draw circle - reads shp->draw(map,template,image);
$circle->draw($map,$emptyLayer,$image);
$image_url=$image->saveWebImage();
function printBusiness($featureLayer,$shp){
$featureLayer->queryByShape($shp);
$numResults = $featureLayer->getNumResults();
if($numResults > 0){
echo 'if';
return $numResults;
}else{
echo 'else';
return 0;
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130918/18aacfb3/attachment-0001.html>
