[mapserver-users] Mapcache with mapfile as layer
Stephen Woodbridge
woodbri at swoodbridge.com
Thu Sep 19 15:53:46 PDT 2013
If you modify the mapfile then it invalidates the whole cache for the
tileset and you have other maintenance to do on it anyway. I would write
a script that does the maintenance of checking the for mapfile changes,
deleting the invalid tiles maybe updating the mapcache.xml, etc.
-Steve W
On 9/19/2013 3:45 PM, Pablo Cecconi wrote:
> The problem with that approach is that is the mapfile changes (a layer
> is added or the default status of a layer changes) then I also have to
> update mapcache config file. What i wonder is if there is a way to just
> modify the map and have Mapcache reflecting that change.
> Pablo
> On Thu, Sep 19, 2013 at 4:40 PM, Stephen Woodbridge
> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>> wrote:
> On 9/19/2013 3:02 PM, Pablo Cecconi wrote:
> Hello,
> I've been a Mapserver user for many years now but I'm new to
> Mapcache
> and I'm not sure whether it's possible to replicate a particular
> TileCache setup using Mapcache.
> What we have today is a number of mapfiles (with Mapserver 5.4)
> set up
> as WMS-C layers served with TileCache. We're migrating to Mapserver
> 6.2.1 and as it's incompatible with TileCache we expect to be
> able to
> replace it using Mapcache.
> In our current setup if I have a mapfile where a particular
> layer has
> STATUS OFF then TileCache will honor that status and not render
> the layer.
> I'd like to know whether it's possible to have MapCache work
> that way,
> that is, passing the map name as the LAYERS parameter of the WMS
> service
> and make it honor whatever STATUS a particular layer would have
> in the
> mapfile.
> I think the mapcache paradigm for this in mapcache works like this:
> tileset
> name=foo
> source=foo-source
> source
> name=foo-source
> map=/path/to/mapfile
> layers=layer1,layer2,layers3,.__..
> So you can configure which layers a tileset returns. I'm not sure
> how it deals with the status off, but it will work if you define the
> list explicitly. This also allow you to do this in the same mapcache.xml
> tileset
> name=foo2
> source=foo-source2
> source
> name=foo-source2
> layers=streets,...
> transparent=true
> I do this a lot when I have a subset of data like streets that I
> want to render as an overly on a raster image
> -Steve W
> _________________________________________________
> mapserver-users at lists.osgeo.__org
> <mailto:mapserver-users at lists.osgeo.org>
> http://lists.osgeo.org/__mailman/listinfo/mapserver-__users
> <http://lists.osgeo.org/mailman/listinfo/mapserver-users>
