[mapserver-users] Mapcache with mapfile as layer
Pablo Cecconi
pc at educ.ar
Thu Sep 19 19:24:14 PDT 2013
Well, maybe I'm not getting it right but it seems to me that this file:
https://github.com/mapserver/mapcache/blob/master/lib/source_mapserver.c
and this example in the
https://github.com/mapserver/mapcache/blob/master/mapcache.xml.sample:
<source name="osm" type="wms">
<http>
<url>http://localhost/cgi-bin/mapserv?</url>
</http>
<getmap>
<params>
<FORMAT>image/png</FORMAT>
<LAYERS>default</LAYERS>
<!--<MAP>/Users/tbonfort/dev/mapserver-utils/empty.map</MAP>-->
<MAP>/Users/tbonfort/dev/mapserver-utils/osm-google.map</MAP>
</params>
</getmap>
</source>
would suggest that, although not documented, mapcache might be able to talk
to mapserver through the cgi protocol if built with the USE_MAPSERVER flag.
I can't wait to test it!
On Thu, Sep 19, 2013 at 11:08 PM, Stephen Woodbridge <
woodbri at swoodbridge.com> wrote:
> Thanks, I would be interested in hearing how you work this out. It might
> help to remember that mapcache ONLY talks to mapserver via the WMS
> protocol, NOT the mapserver CGI protocol. This is a big difference from
> TileCache. Anyway good luck with your efforts.
> -Steve
> On 9/19/2013 10:00 PM, Pablo Cecconi wrote:
>> The problem is not the invalidation of the tiles (which is a very simple
>> step that can even be done with a simple bash script) but the need to
>> list every single layer with status ON on the mapfile. To do that
>> automatically we need to use mapscript (as TileCache does) but we also
>> need to deal with generating a valid mapcache config file (which we
>> cannot do with mapscript). With TileCache instead we just mapped a given
>> layer name with a mapfile and we only had to care about invalidating and
>> reseeding of tiles and not with modifying TileCache config file. It's
>> not so bad though. I just thought that being part of Mapserver maybe
>> MapCache could have some kind of "special integration" with it.
>> Anyway, I'll continue digging to see if I find some easier way to deal
>> with this particular problem and if I do I promise to let you know.
>> Thanks again.
>> Pablo
>> On Thu, Sep 19, 2013 at 10:18 PM, Stephen Woodbridge
>> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.**com<woodbri at swoodbridge.com>>>
>> wrote:
>> Try it, it might work, I don't remember, but you still have the
>> problem of invalidating the tiles when you changes the mapfile. But
>> seriously, your approach seems a little haphazard. Also how often to
>> you make mapfile changes? how did you deal with the invalidating
>> cache problem before?
>> The big difference here is that mapcache is using mapserver as a WMS
>> source and therefore it has to conform to the WMS rules.
>> Anyway, Thomas is the one that you would need to convince or fund if
>> you want changes to the existing behavior. Meanwhile it would be
>> worthwhile your time to figure out how it curently works before
>> asking for features that might already exist. It has been a few
>> months since I setup a mapcache instance and I know there have been
>> changes that I'm not on top of in the newest release.
>> -Steve
>> On 9/19/2013 3:46 PM, Pablo Cecconi wrote:
>> The problem with that approach is that is the mapfile changes (a
>> layer
>> is added or the default status of a layer changes) then I also
>> have to
>> update mapcache config file. What i wonder is if there is a way
>> to just
>> modify the map and have Mapcache reflecting that change.
>> Pablo
>> On Thu, Sep 19, 2013 at 4:40 PM, Stephen Woodbridge
>> <mailto:woodbri at swoodbridge.__**com
>> <mailto:woodbri at swoodbridge.**com <woodbri at swoodbridge.com>>>>
>> wrote:
>> On 9/19/2013 3:02 PM, Pablo Cecconi wrote:
>> Hello,
>> I've been a Mapserver user for many years now but I'm
>> new to
>> Mapcache
>> and I'm not sure whether it's possible to replicate a
>> particular
>> TileCache setup using Mapcache.
>> What we have today is a number of mapfiles (with
>> Mapserver 5.4)
>> set up
>> as WMS-C layers served with TileCache. We're migrating
>> to Mapserver
>> 6.2.1 and as it's incompatible with TileCache we expect
>> to be
>> able to
>> replace it using Mapcache.
>> In our current setup if I have a mapfile where a
>> particular
>> layer has
>> STATUS OFF then TileCache will honor that status and
>> not render
>> the layer.
>> I'd like to know whether it's possible to have MapCache
>> work
>> that way,
>> that is, passing the map name as the LAYERS parameter
>> of the WMS
>> service
>> and make it honor whatever STATUS a particular layer
>> would have
>> in the
>> mapfile.
>> I think the mapcache paradigm for this in mapcache works
>> like this:
>> tileset
>> name=foo
>> source=foo-source
>> source
>> name=foo-source
>> map=/path/to/mapfile
>> layers=layer1,layer2,layers3,.**____..
>> So you can configure which layers a tileset returns. I'm
>> not sure
>> how it deals with the status off, but it will work if you
>> define the
>> list explicitly. This also allow you to do this in the same
>> mapcache.xml
>> tileset
>> name=foo2
>> source=foo-source2
>> source
>> name=foo-source2
>> layers=streets,...
>> transparent=true
>> I do this a lot when I have a subset of data like streets
>> that I
>> want to render as an overly on a raster image
>> -Steve W
>> ______________________________**_____________________
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.__**__org
>> <mailto:mapserver-users at lists.**__osgeo.org
>> <mailto:mapserver-users at lists.**osgeo.org<mapserver-users at lists.osgeo.org>
>> http://lists.osgeo.org/____**mailman/listinfo/mapserver-___**
>> _users <http://lists.osgeo.org/____mailman/listinfo/mapserver-____users>
>> <http://lists.osgeo.org/__**mailman/listinfo/mapserver-__**users<http://lists.osgeo.org/__mailman/listinfo/mapserver-__users>
>> <http://lists.osgeo.org/**mailman/listinfo/mapserver-**users<http://lists.osgeo.org/mailman/listinfo/mapserver-users>
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130919/a27abbb3/attachment.html>
