[mapserver-users] WMS server error. Invalid layer(s) given in the LAYERS parameter
Paul S
paul.sheedy at bentley.com
Mon Sep 23 06:43:47 PDT 2013
I am not sure if I double-posted this - if so - apologies!
I installed MS4W a few days ago to put together a small proof-of-concept.
I've been through the tutorial, which I got to work with a little tweaking.
When I attempt to use an Oracle spatial table, I get a MS server error:
Invalid layers(s)... error - which gives me little indication of where I am
going wrong.
Can anyone spot a problem here? I am running out of hair to pull out.
I have the Oracle client installed on my local machine and am attempting to
draw a map from a spatial table on a local vm on which I have Oracle Spatial
running (10g).
I tried OGRINFO using the Oracle login credentials and table name - with
immediate success.
mapserv -v shows that ORACLESPATIAL is a valid option
GetCapabiltiies contains no warnings
The map file is very simple - I have tried at least one hundred variations.
The data table has a SRID (though I have other tables with SRIDs and tables
without). I've included the SRID in wms_srs and I have excluded it. I am
beginning to believe the problem lies elsewhere - but have no idea what
approach to use to find it, other than stabbing in the dark.
The map file contents are listed below. Thanks for any advice/pointers you
can offer.
MAP
NAME "Map1"
SIZE 600 400
WEB
IMAGEPATH "/tmp/ms_tmp/"
TEMPLATE "..\Templates\TEMPLATE2.HTML"
METADATA
"wms_enable_request" "*"
"wms_title" "TestMap"
"wms_srs" "EPSG:2205"
END
END
LAYER
NAME TestMap
TYPE LINE
STATUS ON
UNITS METERS
CONNECTIONTYPE ORACLESPATIAL
CONNECTION "test_user/test_user at LOCALVM1"
DATA "SHAPE FROM (SELECT SHAPE FROM XNA_ROUTES)"
METADATA
"wms_name" "TestMap"
"wms_title" "TestMapTitle"
"wms_srs" "EPSG:4326"
"wms_format" "image/gif"
END
END #LAYER
END #MAP
View this message in context: http://osgeo-org.1560.x6.nabble.com/WMS-server-error-Invalid-layer-s-given-in-the-LAYERS-parameter-tp5079259.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
