[mapserver-users] Mapserver shows all nodes on a GeometryCollection
drobins
d.robins at gisarts.nl
Wed Apr 16 02:44:17 PDT 2014
I'll look a bit deeper into it when I have a bit more time available and try
it the way you suggest by building the WMS from scratch.
I'm not sure if I can use the shape file as source, because the geometry is
linked to a variety of postgres tables to supply the geometry with
administrative data.
If I happen to find a solution I'll be sure to post it here!
Thanks for your time and help thusfar!
Daniel
View this message in context: http://osgeo-org.1560.x6.nabble.com/Mapserver-shows-all-nodes-on-a-GeometryCollection-tp5135064p5135348.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
