[mapserver-users] mapcache check cache before testing source data?
thomas bonfort
thomas.bonfort at gmail.com
Thu Apr 24 11:32:57 PDT 2014
Jerry,
I'm not sure I follow your issue. Mapcache itself won't hit your
source data, it will only be accessed through by the configured wms
server if a tile was not found in the local cache. The seeder will
only hit the wms if a given tile was not present in the cache (or if
you have passed --force on the command line)
thomas
On 23 April 2014 21:33, jrumbolt <cankorusa at gmail.com> wrote:
> Hi,
> I have my source datasets on Amazon S3 and mounted with s3fs. There is a
> fair amount of latency in any check/read in the mounted s3 bucket to I use
> the mapcache_seed to fill a cache on the local system in a one time
> operation.
> I'm finding that mapcache seems to want to check the source data before
> hitting the cache and it's slow, high latency, even though the cache is
> local and ready.
> Is there some option that I can set that will have mapcache get from the
> cache first before trying to do anything with the source data?
> Regards,
> Jerry
> View this message in context: http://osgeo-org.1560.x6.nabble.com/mapcache-check-cache-before-testing-source-data-tp5136792.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at lists.osgeo.org
