[mapserver-users] mapcache check cache before testing source data?
thomas bonfort
thomas.bonfort at gmail.com
Thu Apr 24 13:20:36 PDT 2014
Jerry,
mapcache has no knowledge of where there's data or not. If it has the
requested tile in its cache it will serve it, otherwise it will ask
the wms to render it, then cache it, then serve it. Wether the wms hit
actual data or not is not mapcache's problem.
thomas
On 24 April 2014 21:58, jrumbolt <cankorusa at gmail.com> wrote:
> Thomas,
> Hmmm... that means the for some reason mapcache is not using my cache. As a
> test if, if I seed the cache and then point the map to some nonexisting data
> then as long as the requests are of an area that I seeded then it should
> still work, correct?
> Regards,
> Jerry
> View this message in context: http://osgeo-org.1560.x6.nabble.com/mapcache-check-cache-before-testing-source-data-tp5136792p5136981.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at lists.osgeo.org
