[mapserver-users] NoData Gap between rasters - Tileindex Layer
Bartlomiej Burkot pomiarowiec10 at poczta.onet.pl
Thu Aug 28 05:03:46 PDT 2014
Dear MS Users
Please look at the attachement and maybe you will recognize the problem.
I think some of you could have encountered this problem with one pixel
gap between rasterfiles in tileindex layer?
Description:
I have a set of rasters which I warped to epsg:3857 projection using
gdalwarp.
During the reprojecting the new raster had been rotated by small angle.
After that I created a tileindex shape file using gdaltindex and
configured layer:
LAYER
         NAME "myname"
         TILEINDEX "tilindex.shp"
         TYPE RASTER
         OFFSITE 0 0 0
     END
On the result map I see the gaps between raster files in the layer. (See
the attachment).
Mayby there is a option in gdalwarp command to extend the new image by
making it 1 pixel widther? May by something like resampling method or
algorithm?
Could you please pint me to the solution of this problem?
Thanks in advance
Bartek
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140828/682b874a/attachment.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140828/682b874a/attachment.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140828/682b874a/attachment-0001.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140828/682b874a/attachment-0002.png>
More information about the MapServer-users mailing list
