[mapserver-users] maxscale (denom) with gml ?
bpicinbono at worldonline.fr
Mon Dec 1 14:05:13 PST 2014
from the ol3 extract of my last post (below), it's WFS as I see:
format: new ol.format.WFS({
regards
On 12/01/2014 10:12 PM, Lime, Steve D (MNIT) wrote:
> I meant what so the calls to MapServer from OpenLayers look like? Are you
using WFS, custom MapServer queries or perhaps OGR output formats? Doesn't look
like the latter from your mapfile.
> Steve
> -----Original Message-----
> From: mapserver-users-bounces at lists.osgeo.org
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of
> Sent: Monday, December 01, 2014 3:06 PM
> To: mapserver-users at lists.osgeo.org
> Subject: Re: [mapserver-users] maxscale (denom) with gml ?
> Many thanks for investigating;
> please check below the relevant parts of the mapfile, as well as the
openlayers related code; (the purpose is to display nooa gfs winds forecasts,
"vents" means "winds" in french);
> some stuff like the SYMBOL part and the layer's STYLE part should not be
necessary anymore with gml output, as well as few other directives, clean up job
ahead..., but working, minus the maxscale (denom) directive which is not working
in this configuration;
> I could manage the scale display control on the openlayers 3 side with an if
case based on the zoom level, but I would prefer mapserver mapfile to drive it;
> Thanks again
> Blaise
> --- mapfile ---
> (called rg_noaa_vents_gml.map, called on the ol3 side)
> MAP
> NAME rg_noaa
> STATUS ON
> SIZE 600 600
> EXTENT -180 -90 180 90
> FONTSET "fonts/fonts.list"
> UNITS DD
> SHAPEPATH "data"
> IMAGECOLOR 230 230 255
> TEMPLATEPATTERN "rg_noaa"
> IMAGETYPE PNG24
> OUTPUTFORMAT
> # image mapfile #
> #TRANSPARENT ON
> #IMAGEMODE RGB
> #DRIVER GD/PNG
> # gml mapfile #
> NAME "gml"
> DRIVER "TEMPLATE"
> FORMATOPTION "FILE=rg_noaa_vent_gml.map"
> END
> PROJECTION
> "init=epsg:4326"
> END
> WEB
> HEADER templates/header_ol.html
> TEMPLATE "set in index.html"
> FOOTER templates/footer.html
> MAXSCALE 200000000
> IMAGEPATH "/tmp/ms_tmp/"
> IMAGEURL "/ms_tmp/"
> METADATA
> "WMS_TITLE" "vrrroum_noaa"
> "WMS_ONLINERESOURCE"
"http://localhost/cgi-bin/mapserv?map=/var/www/html/rg/blabla_02/noaa/rg_noaa_vents_gml.map"
> "WMS_SRS" "EPSG:4326"
> "WMS_ENABLE_REQUEST" "*"
> #"WMS_FEATURE_INFO_MIME_TYPE" "text/html"
> "wms_feature_info_mime_type" "text/gml"
> "WFS_ONLINERESOURCE"
"http://ip-adress/cgi-bin/mapserv?map=/var/www/rg/blabla_02/noaa/rg_noaa_vents_gml.map&"
> "WFS_ENABLE_REQUEST" "*"
> "wfs_feature_info_mime_type" "text/gml"
> END
> END
> SYMBOL
> NAME "arrowfilled"
> TYPE vector
> FILLED true
> #FILLED false
> POINTS
> 1 0
> -1 0
> -1 7
> -3 7
> 0 10
> 3 7
> 1 7
> 1 0
> -1 0
> END # POINTS
> END # SYMBOL
> LAYER ##### ##### ##### fv_168
> NAME fv_168
> GROUP v_168
> TYPE POINT
> STATUS ON
> DATA fv_168
> MAXSCALEDENOM 20000000
> SIZEUNITS kilometers
> METADATA
> "WMS_TITLE" "v_168"
> "WMS_SRS" "epsg:4326"
> "wms_include_items" "all"
> "gml_include_items" "all"
> "wfs_title" "v_168"
> "wfs:srs" "EPSG:4326"
> "gml_featureid" "ID"
> "wfs_enable_request" "*"
> END
> CLASS
> TEMPLATE "templates/vents.html"
> STYLE
> OPACITY 50
> SYMBOL "arrowfilled"
> SIZE [VITREP]
> ANGLE [ANGLE]
> WIDTH 2
> COLOR 100 100 150
> END
> END
> DUMP TRUE
> HEADER "templates/vents_header_ol.html"
> FOOTER "templates/vents_footer_ol.html"
> TOLERANCE 20
> END
> END # Map File
> --- openlayers 3 ---
> (extracts of the layer description)
> var gmlSourceV_168 = new ol.source.ServerVector({
> layer: 'v_168gml',
> featureNS: "http://mapserver.gis.umn.edu/mapserver",
> featureType: 'fv_168'
> projection: 'EPSG:4326',
> loader: function(extent, resolution, projection) {
> $.ajax({
> url:
'http://ip-adress/cgi-bin/mapserv?map=/var/www/html/rg/blabla_02/noaa/rg_noaa_vents_gml.map&service=WFS&'
> 'version=1.1.0&request=GetFeature&typename=fv_168&outputFormat=text/xml;
> subtype=gml/3.1.1&' +
> '&srsname=EPSG:4326&bbox=' + extent.join(',')
> }).done(
> function(response) {
> gmlSourceV_168.addFeatures(gmlSourceV_168.readFeatures(response));
> strategy: ol.loadingstrategy.bbox
> var gmlLayerV_168 = new ol.layer.Vector({
> title: '168gml',
> type: 'base',
> visible: false,
> source: gmlSourceV_168,
> style: (function() {
> function ruleStyle(vitrep, angle, lon, lat) {
> var ruleStyle = [new ol.style.Style({
> image: new ol.style.Icon({
> src: 'images/windarrow_42.png',
> rotation: angle * 3.141592654 / 180
> return ruleStyle;
> return function(feature, resolution) {
> var vitrep = feature.get('VITREP');
> var angle = - feature.get('ANGLE');
> var lon = feature.getX;
> var lat = feature.Y;
> return ruleStyle(vitrep, angle, lon, lat);
> On 12/01/2014 08:50 PM, Lime, Steve D (MNIT) wrote:
>> How are you triggering the GML production in MapServer?
>> Sent: Monday, December 01, 2014 11:01 AM
>> Subject: [mapserver-users] maxscale (denom) with gml ?
>> Dear list,
>> I have a mapfile that control the display of some numerous data
>> depending on
> the
>> scale:
>> - dezooming max: not displaying the shapes;
>> - at a particular zooming-in level: displaying the shapes;
>> This is done with:
>> MAXSCALE 200000000
>> in the WEB section of the mapfile
>> and with:
>> in the layer section of the mapfile
>> This works fine rendering images with a basic cgi mapserver
>> application or in
> an opelayers 3 application.
>> I am now trying to get the same behaviour in an openlayers 3
>> application but
> rendering the shapes on client side through gml instead of server side image
rendering.
>> Gml rendering works fine, but it seems that the MAXSCALE (DENOM)
>> directive is
>> omitted: the shapes display is no more turned off when dezooming a lot.
>> Any clue to have this MAXSCALE ( DENOM ) working with gml display ?
>> Thanks in advance
>> mapserver-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
