[mapserver-users] Extract raster point values with mapserver
William Hudspeth
bhudspeth at edac.unm.edu
Sat Dec 13 12:14:39 PST 2014
Hello,
This is how Postgresql makes the data available. PostgresQL stores the
information about the location of the geotiffs and the timestamp
associated with them:
pm25_monthly=# \d pm25_monthly_global
Table "public.pm25_monthly_global"
Column | Type | Modifiers
oid | integer | default
nextval('pm25_monthly_seq'::regclass)
rundate | timestamp with time zone |
datetime | timestamp with time zone |
location | text |
timezone | timestamp without time zone |
the_geom | geometry(MultiPolygon,4326) |
Indexes:
"pm25_monthly_global_oid_key" UNIQUE CONSTRAINT, btree (oid)
The 'location' field simply gives the full path to the relevant geotiff
on the file system. And, I define the index in the mapfile:
#*********************************************LAYER - TILE INDEX FOR
PM2.5 RASTERS (Time sensitive) **********************************
LAYER
STATUS ON
NAME "pm25_time_index"
TYPE POLYGON
DATA "the_geom from pm25_monthly_global using unique oid using SRID=4326"
METADATA
"ows_title" "PM25 TIME INDEX"
"ows_srs" "EPSG:4326"
"ows_extent" "-180 -90 180 90" #[minx][miny][maxx][maxy]
"wms_timeformat" "YYYY-MM-DDTHH:MM:SS"
"wms_timeextent" "2011-01-01T00:00:00/2012-12-01T00:00:00"
"wms_timeitem" "timezone"
"wms_timedefault" "2011-01-01T00:00:00"
wcs_resolution '0:10 0:10'
# wcs_resolution '0.10 0.10'
END
#CONNECTION "user=wilbur dbname=pm25_monthly host=localhost
password=iiiiiiiiii"
#CONNECTIONTYPE postgis
CONNECTIONTYPE POSTGIS
CONNECTION "host=127.0.0.1 dbname=pm25_monthly user=wilbur
password=EUR2_live port=5432"
DATA "the_geom from pm25_monthly_global using unique oid using srid=4326"
END
#*********************************************LAYER - MONTHLY PM2.5
(Time Sensitive)*********************************
#http://localhost/cgi-bin/mapserv?map=/var/www/pm25_mapserver/public_html/pm25_ogc_services.map&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&LAYERS=pm25_monthly&STYLES=&SRS=EPSG:4326&BBOX=-180,-90,180,90&WIDTH=1600&HEIGHT=800&FORMAT=image/png&SLD=http://localhost/pm25_mapserver/public_html/pm25_sld.xml&TIME=2011-09-01T00:00:00Z
LAYER
NAME 'pm25_monthly'
TYPE RASTER
STATUS ON
DEBUG OFF
DUMP TRUE
#TRANSPARENCY 50
#FILTER ""
METADATA
"ows_keywordlist" 'PM2.5 (ug/m3), Global' #wms_keywordlist
(Keywordlist)
"ows_description" "Global monthly mean PM 2.5 (ug/m3)concentration"
"ows_name" "Global monthly mean PM2.5 - Concentration Values
(ug/m3)"
"ows_label" "Global PM 2.5 (ug/m3)"
"ows_srs" "EPSG:4326 EPSG:900913"
"ows_formats" "GEOTIFF"
"ows_nativeformat" "8-bit GeoTIF"
"ows_timeitem" "timezone"
"wms_onlineresource"
"http://localhost/cgi-bin/mapserv?map=/var/www/pm25_mapserver/public_html/pm25_ogc_services.map"
"wms_abstract" 'Global monthly mean PM 2.5
(ug/m3)concentration' #wms_abstract(Abstract)
"wms_opaque" '0' #wms_opaque(layer)
"wms_title" "Global monthly mean PM 2.5 (ug/m3)concentration"
"ows_timeformat" "YYYY-MM-DDTHH:MM:SSZ"
"ows_timeextent" "2011-01-01T00:00:00Z/2012-12-01T00:00:00Z"
"ows_timedefault" "2011-01-01T00:00:00Z"
"wms_enable_request" "*"
"wcs_resolution" "0:10 0:10"
#"wcs_resolution" "0.10 0.10"
"wcs_bandcount" "1"
"wcs_size" "3600 1800"
layer_name pm25_monthly
END #METADATA
PROJECTION
"init=epsg:4326" #WGS84 Decimal Degrees
END #PROJECTION
TILEITEM "location"
TILEINDEX "pm25_time_index"
END #LAYER
Thanks
