[mapserver-users] Left click loses CGI variables
Stephen Davies
sdavies at sdc.com.au
Wed Dec 17 18:32:44 PST 2014
When sending output to PDA devices, I use a direct call to mapserv with
several run-time substitution variables to set filters.
This works perfectly for the initial display but if the user clicks the
resulting map, the redisplay loses all of the variables.
This led to errors in the redisplay because %foo% was no longer replaced so I
added default_foo entries to the mapfile.
This prevents the errors but means that nothing matches the default filter.
How can I tell mapserv to retain the original variables?
Cheers and thanks,
Stephen
Stephen Davies Consulting P/L Phone: 08-8177 1595
Adelaide, South Australia. Mobile:040 304 0583
Records & Collections Management.
