[mapserver-users] [mapserver-dev] need help with outputformat=kml for wfs
Lime, Steve D (MNIT)
Steve.Lime at state.mn.us
Fri Dec 19 07:48:02 PST 2014
Ok, let's try this outside of WFS context. You should be able to do something like:
/cgi-bin/mapserv?map=...&mode=map&mapext=...&map.imagetype=kml
Does that work?
Steve
-----Original Message-----
Sent: Friday, December 19, 2014 9:27 AM
To: Lime, Steve D (MNIT)
Cc: mapserver-users; mapserver-dev at lists.osgeo.org
Subject: Re: [mapserver-dev] need help with outputformat=kml for wfs
yes
On 12/18/14, Lime, Steve D (MNIT) <Steve.Lime at state.mn.us> wrote:
> Can you get at the layer GML without the output layer parameter?
> From: mapserver-dev-bounces at lists.osgeo.org
> [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of zach
> cruise
> Sent: Thursday, December 18, 2014 9:18 AM
> To: mapserver-users
> Cc: mapserver-dev at lists.osgeo.org
> Subject: [mapserver-dev] need help with outputformat=kml for wfs
> using-
> * MapServer version 6.4.0 ... OUTPUT=KML ... SUPPORTS=WFS_SERVER
> SUPPORTS=WFS_CLIENT ...
> * httpd file-
> <IfModule mime_module>
> AddType application/vnd.google-earth.kml+xml .kml
> </IfModule>
> * map file-
> MAP
> IMAGETYPE kml
> WEB
> METADATA
> "wfs_getfeature_formatlist" "kml"
> END
> END
> OUTPUTFORMAT
> NAME "kml"
> DRIVER KML
> MIMETYPE "application/vnd.google-earth.kml.xml"
> IMAGEMODE RGB
> IMAGEMODE FEATURE
> EXTENSION "kml"
> FORMATOPTION "ATTACHMENT=doc.kml"
> END
> LAYER
> END
> END
> * url-
> ../cgi-bin/mapserv?SERVICE=wfs&REQUEST=getfeature&TYPENAME=shoppinglis
> t&VERSION=1.0.0&OUTPUTFORMAT=kml
> (with or without "MODE=map")
> but all i get is (no placemarks for points?)- <?xml version="1.0"
> encoding="UTF-8"?> <kml xmlns="http://www.opengis.net/kml/2.2">
> <Document>
> <Style id="LayerFolder_check">
> <ListStyle>
> <listItemType>check</listItemType>
> </ListStyle>
> </Style>
> <Style id="LayerFolder_checkHideChildren">
> <ListStyle>
> <listItemType>checkHideChildren</listItemType>
> </ListStyle>
> </Style>
> <Style id="LayerFolder_checkOffOnly">
> <ListStyle>
> <listItemType>checkOffOnly</listItemType>
> </ListStyle>
> </Style>
> <Style id="LayerFolder_radioFolder">
> <ListStyle>
> <listItemType>radioFolder</listItemType>
> </ListStyle>
> </Style>
> <name>shoppingmap</name>
> <Folder>
> <name>shoppinglist</name>
> <visibility>1</visibility>
> <styleUrl>#LayerFolder_check</styleUrl>
> </Folder>
> </Document>
> </kml>
> mapserver-dev mailing list
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
