[mapserver-users] Map collaring techniques.
Basques, Bob (CI-StPaul)
bob.basques at ci.stpaul.mn.us
Fri Dec 19 07:46:01 PST 2014
All,
Anyone have any insights into using/modifying MapServer to label maps collar wise (along the edges)??
I'm interested in applying USNG collaring to maps in general as a grid overlay. I'm pretty sure I ca do this with PERL, but all the re-projection capabilities in MapServer make it much more attractive. There are also quite a fe desires finishing options that I would like to include related to rotation and alignment. I'm open to applying the collar on or off (outside of ) the map itself.
I've worked with both the ESRI and AutoDesk tools for accomplishing the same results as well. AutoDesk has a fairly well thought out XML file format for defining the grid labeling, it's almost SLD-ish as a matter of fact. I've also been involved in a couple of Javascript mashups to provide USNG overlays to maps, but they aren't hardcopy centric, which is what I need to focus on.
Thanks
Bobb
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20141219/f58603a6/attachment.html>
