[mapserver-users] Map collaring techniques.
Brent Fraser
bfraser at geoanalytic.com
Sat Dec 20 07:48:22 PST 2014
Bob,
Years ago we had experimented with using Mapserver to do automated
mapping (to produce printed maps 34 x 46 inches). The maps were of
pipeline alignments and needed to be rotated so the pipeline was roughly
parallel to the X axis of the paper. And they required imagery as a
backdrop. And they required a [rotated] labelled graticule. In the end
we had to use a combination of Mapserver, Arcview, and custom s/w.
Let me know how your efforts turn out...
Best Regards,
Brent Fraser
On 12/19/2014 12:43 PM, Basques, Bob (CI-StPaul) wrote:
> Hi Brent,
> Neat trick there, and straightforward too.
> I had thought about doing some sort of pipeline for drawing with
> MapServer, by simply drawing different grid areas at each step in the
> pipeline. One step for each side of the map for example. I know I
> can do it with MapSCRIPT, but being able to pass in a image to
> MapServer would be the cool way.
> Bobb
> *From:*Brent Fraser [mailto:bfraser at geoanalytic.com]
> *Sent:* Friday, December 19, 2014 10:58 AM
> *To:* Basques, Bob (CI-StPaul); mapserver-users at lists.osgeo.org
> *Subject:* Re: [mapserver-users] Map collaring techniques.
> Bob,
> In the past I've dabbled with having layers to " erase"the map data
> around the perimeter:
> LAYER
> NAME "Margin"
> TRANSFORM FALSE
> STATUS DEFAULT
> TYPE POLYGON
> CLASS
> COLOR 255 255 255
> END
> FEATURE
> POINTS 0 0 0 600 70 600 70 0 0 0 END
> POINTS 70 0 70 70 800 70 800 0 70 0 END
> POINTS 70 600 800 600 800 530 70 530 70 600 END
> POINTS 730 70 730 530 800 530 800 70 730 70 END
> END
> END
> LAYER
> NAME "NeatLine"
> TRANSFORM FALSE
> STATUS DEFAULT
> TYPE LINE
> CLASS
> COLOR 0 0 0
> END
> FEATURE
> POINTS 70 70 70 530 730 530 730 70 70 70 END
> END
> END
> Also I've experimented with adding FORMATOPTIONs to OUTPUTFORMAT code
> (see
> http://lists.osgeo.org/pipermail/mapserver-dev/2009-January/008050.html)
> How big do you plan to make your maps? Will they include imagery?
> Best Regards,
> Brent Fraser
> On 12/19/2014 8:46 AM, Basques, Bob (CI-StPaul) wrote:
> All,
> Anyone have any insights into using/modifying MapServer to label
> maps collar wise (along the edges)??
> I’m interested in applying USNG collaring to maps in general as a
> grid overlay. I’m pretty sure I ca do this with PERL, but all the
> re-projection capabilities in MapServer make it much more
> attractive. There are also quite a fe desires finishing options
> that I would like to include related to rotation and alignment.
> I’m open to applying the collar on or off (outside of ) the map
> itself.
> I’ve worked with both the ESRI and AutoDesk tools for
> accomplishing the same results as well. AutoDesk has a fairly
> well thought out XML file format for defining the grid labeling,
> it’s almost SLD-ish as a matter of fact. I’ve also been involved
> in a couple of Javascript mashups to provide USNG overlays to
> maps, but they aren’t hardcopy centric, which is what I need to
> focus on.
> Thanks
> Bobb
> mapserver-users at lists.osgeo.org <mailto:mapserver-users at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20141220/001d2536/attachment.html>
