[mapserver-users] Mapserver as WFS 1.1.0 client
Lime, Steve D (MNIT)
Steve.Lime at state.mn.us
Tue Dec 23 09:11:12 PST 2014
Based on other input from Daniel Morissette I think it's pretty safe to say that MapServer only supports WFS layers with versions 0.0.14 and 1.0.0. Sorry... I don't know what it would take to extend things to 1.1.0 though (patches welcome).
Steve
-----Original Message-----
From: Lars Fricke [mailto:lars.fricke at skendata.de]
Sent: Tuesday, December 23, 2014 10:58 AM
To: Lime, Steve D (MNIT); mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Mapserver as WFS 1.1.0 client
Hello Steve,
Thank you for your answer. I tried setting to GET and this is what i got:
"<ows:Exception exceptionCode="NoApplicableCode"
locator="mapserv"><ows:ExceptionText>msWFSGetFeature(): WFS server error. ms_error->code not found
msWFSLayerWhichShapes(): WFS connection error. WFS request produced unexpected output (junk?) for layer HK.</ows:ExceptionText></ows:Exception>"
The message about the wrong version is not showing up.
Maybe I'm doing something wrong?
Here's my layer definition:
"LAYER
NAME "HK"
TYPE Point
UNITS METERS
CONNECTION "http://localhost:8081/geoserver/wfs?"
CONNECTIONTYPE WFS
#EXTENT 618740 5962679 1737924 7376186 does not seem to matter
STATUS ON
METADATA
"wfs_version" "1.1.0"
"wfs_title" "HK"
"wfs_connectiontimeout" "60"
"wfs_typename" "Data:HK"
"wfs_maxfeatures" "500"
"wfs_request_method" "GET"
"gml_include_items" "all"
"wfs_title" "HK"
"wfs_srs" "EPSG:3857"
"gml_featureid" "GCOA_ID"
"wfs_enable_request" "*"
END # METADATA
PROJECTION
"init=epsg:3857"
END # PROJECTION
CLASS
NAME "Koordinaten"
STYLE
COLOR 190 87 66
OUTLINECOLOR 255 0 0
SIZE 4
SYMBOL "circle_filled"
END # STYLE
END # CLASS
END # LAYER"
The request is:
"http://localhost:8082/wfs?SERVICE=WFS&VERSION=1.1.0&&request=GetFeature&TYPENAME=HK&local&SRS=EPSG:3857&bbox=793732,6570204,793765,6570228"
Thank you
Cheers
Lars
Am 22.12.2014 um 16:09 schrieb Lime, Steve D (MNIT):
> Looking at the mapwfslayer.c code it's a little confusing. I see references to 0.0.14 and 1.0.0 for POST requests and 0.0.14, 1.0.0 and 1.1 for GET requests. You can try setting:
> In the layer metadata and see if that works for you.
> Steve
> From: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Lars
> Fricke
> Sent: Monday, December 22, 2014 12:58 AM
> To: mapserver-users at lists.osgeo.org
> Hello List,
> can you please give me a quick feedback on which version WFS MapServer supports as CLIENT (see below)? I can't really find it in the docs.
> Thank you.
> Lars Fricke
> Am 18.12.2014 um 08:29 schrieb Lars Fricke:
>> Hello,
>> I am trying to access an external WFS with MapServer as client to
>> cascade it. I get the following error message:
>> msBuildWFSLayerPostRequest(): WFS connection error. MapServer
>> supports only WFS 1.0.0 or 0.0.14 (please verify the version metadata
>> wfs_version).
>> Indeed the external server only sends version 1.1.0 and my mapfile has:
>> METADATA
>> Now when I search on the net, I find bug reports about WMS 1.1.0 and
>> MapServer but no information if I can use it as a 1.1.0 client at all.
>> And if so, do I need to use something specific to activate it?
>> I'm on a German Ubuntu 14.04 64bit with Apache2 and mapserv -v says:
>> MapServer version 6.4.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=KML
>> SUPPORTS=PROJ SUPPORTS=GD SUPPORTS=AGG SUPPORTS=FREETYPE
>> SUPPORTS=CAIRO SUPPORTS=SVG_SYMBOLS SUPPORTS=RSVG SUPPORTS=ICONV
>> SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
>> SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER
>> SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS SUPPORTS=GEOS
>> INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
>> Thanks for looking into this.
>> Best
>> Lars
>> mapserver-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
