[mapserver-users] Setting up a JSONP service
Even Rouault
even.rouault at spatialys.com
Mon Dec 29 16:36:18 PST 2014
Le mardi 30 décembre 2014 00:55:59, Jeff McKenna a écrit :
> On 2014-12-29 6:34 AM, Lars Fricke wrote:
> > Dear List,
> > I have a WFS service running under MapServer that I would like to
> > operate as JSONP service. I managed to set GEOJSON as output format but
> > I get "Cross-Origin-Request Blocked" if I try to call it with a
> > Javascript client (using Leaflet L.layerJSON.
> > The question is: Is it possible to set up a JSONP service from Mapserver
> > and if yes, how? My current mapfile looks like this (relevant parts):
> > # in WEB - METADATA
> > "wfs_getfeature_formatlist" "geojson,csv,ogrgml"
> > OUTPUTFORMAT
> > NAME "geojson"
> > DRIVER "OGR/GEOJSON"
> > MIMETYPE "application/json; subtype=geojson; charset=utf-8"
> > FORMATOPTION "STORAGE=stream"
> > FORMATOPTION "FORM=SIMPLE"
> > FORMATOPTION "LCO:COORDINATE_PRECISION=5"
> > END
> > If this would already be a correct JSONP service, I have to look on the
> > Leaflet side for the error...
> > Thanks for your help.
> > Cheers
> > Lars
> Since you're using the OGR driver, you might want to review the GDAL/OGR
> drive page thoroughly (http://www.gdal.org/drv_geojson.html), or ask
> about JSONP on the GDAL-dev mailing list (I see several discussions
> about JSONP, when I search the mailing list archives
> http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html)
Lars,
AFAICS, this would needs a modest enhancement in the OGR GeoJSON driver to
have for example a FORMAT=JSONP creation option, and probably another one like
JSONP_CALLBACK=the_name_you_wish to define the name of the callback function.
Then you could define:
OUTPUTFORMAT
NAME "jsonp"
MIMETYPE "text/javascript"
FORMATOPTION "LCO:FORMAT=JSONP"
FORMATOPTION "LCO:JSONP_CALLBACK=the_name_you_wish"
END
I see that GeoServer has a way to specify the callback name from a user-
specified "format_options=" vendor specific parameters. We could probably do
something similar with substitution in output format formatoption like
OUTPUTFORMAT
NAME "jsonp"
FORMATOPTION "LCO:JSONP_CALLBACK=%jsonp_callback%"
END
But AFAIK, this is only currently implemented for the FILENAME format option,
so this would require a small enhancement in MapServer too.
Even
http://www.spatialys.com
