[mapserver-users] TinyOWS: Axis order fix wanted
Rahkonen Jukka (Tike)
jukka.rahkonen at mmmtike.fi
Thu Jul 3 01:45:31 PDT 2014
Olivier Courtin wrote:
> On Sat, Jun 28, 2014 at 11:38 PM, Even Rouault <even.rouault at mines-
> paris.org> wrote:
> > The following pull request should fix Jukka's issue :
> > https://github.com/mapserver/tinyows/pull/65
> I've just commited the pull request.
> Thanks for this one Even,
> Jukka could you check on your own that everything is fine for you ?
With pleasure but I need some help. I need detailed instructions for how to compile the version from github with Ubuntu 14.04. I think that the same instructions could be included also in the TinyOWS documentation.
-Jukka Rahkonen-
