[mapserver-users] WMS Client changes slightly BBOX
Peter Hopfgartner
peter.hopfgartner at r3-gis.com
Thu Jul 24 05:20:28 PDT 2014
Hi Worth,
thanks for your quick reply. Anyway, the ratio of the extent and of the
image seem to match al least up to 10 digits. Playing with the numbers,
the error is in the same order of magnitude as if I change image size by
one pixel. I would guess, that there is a "off by 1" error somewhere in
the MapServer code.
Regards,
Peter
On 07/24/2014 01:30 PM, Worth Lutz wrote:
> Peter,
> I have found that if the map size (width and height in pixels) aspect
> ratio does not exactly match the map extents (map units) aspect ratio
> the map extents are adjusted.
> I'm working with MapScript and to get exact scale pdf map I have to
> set map size first and then extent and then scale to get good results.
> I hope this helps.
> *Worth Lutz*
> On 07/24/2014 06:49 AM, Peter Hopfgartner wrote:
>> I'm generating dynamically Map Object, with with a certain extent, in
>> the concrete example
>> 629396.05065523,4984079.9894638,655192.92565523,5019084.3644638
>> In generated Map object uses the WMS client functionality to call WMS
>> services. Anyway, the BBOX get's slightly changed, so that the
>> original scale of 1:100000 gets changed to approx 1:100103, since it
>> calls the WMS services with
>> 629382.807906257,4984062.02007212,655206.168404203,5019102.33385548
>> as can be taken from the web server log files:
>> mmm.mmm.mmm.mmm - - [24/Jul/2014:12:25:58 +0200] "GET
>> /author/services/ows.php?PROJECT=ancitel&MAP=catasto_reti&LANG=xw&OGSTAT=ot3cp0i7qmph4guuof75702m70&RESOLUTION=96&LAYERS=dtm,uso_lombardia,strade_lombardia,g_limiti_amministrativi,g_label,g_0707,g_0704&REQUEST=GetMap&SERVICE=WMS&FORMAT=image/png%3B+mode%3D8bit&STYLES=,,,,,,&HEIGHT=1323&VERSION=1.1.1&SRS=EPSG:32632&WIDTH=975&BBOX=629382.807906257,4984062.02007212,655206.168404203,5019102.33385548&TRANSPARENT=TRUE&EXCEPTIONS=application/vnd.ogc.se_inimage
>> HTTP/1.1" 200 678803 "-" "MapServer/6.4.1 libcurl/7.19.7"
>> This change in scale is beyound te axpected tolerance in this
>> particular use case, where technical data must be plotted in a PDF file.
>> Any help is appreciated. Obvioulsly, I can fetch the WMS services in
>> my code and overlay them "by hand". Anyway, for a couple of reasons
>> this was the preferred approach.
>> Regards,
>> Peter
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
Peter Hopfgartner
R3 GIS Srl - GmbH
Via Johann Kravogl-Str. 2
I-39012 Meran/Merano (BZ)
web : www.r3-gis.com
mail : peter.hopfgartner at r3-gis.com
phone: +39 0473 494949
fax : +39 0473 069902
ATTENZIONE! Le informazioni contenute nella presente e-mail e nei documenti eventualmente allegati sono confidenziali. La loro diffusione, distribuzione e/o riproduzione da parte di terzi, senza autorizzazione del mittente è vietata e può violare il D. Lgs. 196/2003. In caso di ricezione per errore, Vogliate immediatamente informare il mittente del messaggio e distruggere la e-mail.
ACHTUNG! Die in dieser Nachricht oder in den beigelegten Dokumenten beinhalteten Informationen sind streng vertraulich. Ihre Verbreitung und/oder ihre Wiedergabe durch Dritte ist ohne Erlaubnis des Absenders verboten und verstößt gegen das Legislativdekret 196/2003. Sollten Sie diese Mitteilung irrtümlicherweise erhalten haben, bitten wir Sie uns umgehend zu informieren und anschließend die Mitteilung zu vernichten.
WARNING! This e-mail may contain confidential and/or privileged information. If you are not the intended recipient (or have received this e-mail in error) please notify the sender immediately and destroy this e-mail. Any unauthorised copying, disclosure or distribution of the material in this e-mail is strictly forbidden and could be against the law (D. Lgs. 196/2003)
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140724/d72cdafe/attachment.html>
