[mapserver-users] Σχετ: Σχετ: Σχετ: Σχετ: Mapserver can't read mapfile
Stephen Woodbridge
woodbri at swoodbridge.com
Mon Jun 2 13:34:47 PDT 2014
STATUS DEFAULT forces the layer to by on regardless.
STATUS ON allows the laye to be turned on/off and in your request you
need to supply a list of layers to tuen on by name.
shp2img ... -l "my_layer1 my_layer_1"
or in CGI
layers=all&...
layers=my_layer1+my_layer2&...
-Steve
On 6/2/2014 4:10 PM, Stefanos Anastasiou wrote:
> Thanks Bobb
> One more thing... I noticed that if I enter the STATUS default it works
> fine. But if I enter STATUS on the page is blank again.
> Any idea why?
> -Stefanos
> Στις 8:26 μ.μ. Δευτέρα, 2 Ιουνίου 2014, ο/η "Basques, Bob (CI-StPaul)"
> <bob.basques at ci.stpaul.mn.us> έγραψε:
> The Extent uses is based on the source data coordinates,, unless you
> also provide a reprojection block in your mapfile/maplayers.
> Bobb
> *From:*mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] *On Behalf Of *Stefanos
> Anastasiou
> *Sent:* Monday, June 02, 2014 11:20 AM
> *To:* Jeff McKenna; mapserver-users at lists.osgeo.org
> *Subject:* [mapserver-users] Σχετ: Σχετ: Σχετ: Mapserver can't read mapfile
> Wow... I literally copied and pasted the coordinates to the EXTENT
> parameter and it worked. Thank you very much..!! :-)
> I though that the mapfile would only read coordinates that are in
> Long/Lat format in WGS84. My coords were x,y format in Greek grid (EGSA
> '87 - EPSG 2100). So I thought I could only import them in Lon/Lat.
> Thanks a lot!
> -Stefanos
> Στις 7:07 μ.μ. Δευτέρα, 2 Ιουνίου 2014, ο/η Jeff McKenna
> <jmckenna at gatewaygeomatics.com <mailto:jmckenna at gatewaygeomatics.com>>
> έγραψε:
> On 2014-06-02, 12:56 PM, Stefanos Anastasiou wrote:
>> Hi Jeff,
>> thanks for your reply.
>> - I indeed used the ogrinfo utility and I gave me the extent
>> in GCS_GGRS_1987. So I transformed the coordinates to WGS84.
> I'm not sure what you mean here by "I transformed the coordinates".
> Literally copy/paste the extents from ogrinfo into your EXTENT parameter
> in your mapfile.
> -jeff
> Jeff McKenna
> MapServer Consulting and Training Services
> http://www.gatewaygeomatics.com/
> mapserver-users at lists.osgeo.org <mailto:mapserver-users at lists.osgeo.org>
