[mapserver-users] layer groups
Malm Paul
paul.malm at saabgroup.com
Thu Jun 5 05:30:01 PDT 2014
I'm sorry to bother you with a question like this, but I have not found any information.
I have a map file which INCLUDES a lot of layer files.
The layer files defines all layers of a chart.
All the layers in the all layer files are assigned to a GROUP.
When I'm connecting to the wms I would just like to get the GROUP, now I'm getting the GROUP, all separate layers and the whole map. This results in 3 times to much data.
The connection URL I'm using in WorldWind is:http://localhost/cgi-bin/mapserv?map=/tmp/test.map?SERVICE=WMS?REQUEST=Getmap?VERSION=1.1.1?LAYERS=BASE
The map file looks like this:
MAP
NAME 'test'
CONFIG "PROJ_LIB" "/usr/src/mapserver/usr/local/share/proj"
EXTENT -180 -90 180 90
SIZE 800 800
RESOLUTION 300
DEFRESOLUTION 72
PROJECTION
'init=epsg:4326'
END
OUTPUTFORMAT
NAME 'AGG'
DRIVER AGG/PNG
IMAGEMODE RGB
END
WEB
IMAGEPATH '/tmp/'
IMAGEURL '/tmp/'
METADATA
"ows_enable_request" "*"
'wms_title' 'S57TEST'
'wms_srs' 'epsg:4326'
END
END
INCLUDE 'DE110000.lay'
INCLUDE 'FI2SAISE.lay'
END
All layer files looks almost the same but with different connections, the GROUP "BASE" is used to group the same type of layers from different charts.
And the lay files typically looks like this:
LAYER
DATA "LNDARE"
NAME "Ground3"
GROUP "BASE"
METADATA
"wms_title" "Ground3"
END
TYPE POLYGON
STATUS ON
CONNECTIONTYPE OGR
CONNECTION "/tmp/ENC_ROOT/EE/EE3A0403/2/0/EE3A0403.000"
PROCESSING "CLOSE_CONNECTION=DEFER"
MAXSCALEDENOM 600000
CLASS
STYLE
COLOR 222 205 139
END
END
END
##### Seabed layers from scale 3 ######
LAYER
DATA "SBDARE"
NAME "Seabed_Area3"
GROUP "BASE"
METADATA
"wms_title" "Seabed_Area3"
END
TYPE POLYGON
STATUS ON
CONNECTIONTYPE OGR
CLASS
NAME "Seabed_area"
STYLE
COLOR 155 200 163
END
END
END
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140605/937cebde/attachment.html>
