[mapserver-users] color attribute question
Carlos Ruiz
boolean10001 at yahoo.com
Thu Jun 26 08:24:53 PDT 2014
To achieve more flexibility as you want, you have to code a function with PL/pgSQL in PostgreSQL or with PHP/Python/Java/C# with Mapscript to define which is the base color (red, green, blue, yellow ...) and then to calculate the percent in the right RGB channel.
Cheers
Mtro. Carlos Ruiz
On Mon, 6/23/14, Do Wi <dowi84 at gmail.com> wrote:
Subject: Re: [mapserver-users] color attribute question
To: "Carlos Ruiz" <boolean10001 at yahoo.com>
Date: Monday, June 23, 2014, 2:56 PM
thanks allot!
Steve and another user here mentioned this path
and it did work!only problem is that it cannot be
changed later if for example the user chooses a blue
gradient.
how will i go about doing it with
mapscript?
maybe it relates to my question herehttp://gis.stackexchange.com/questions/102862/when-to-choose-mapscript-over-mapfile-or-vice-versa
thanks allot!dovi
On Mon, Jun 23, 2014
at 6:13 PM, Carlos Ruiz <boolean10001 at yahoo.com>
wrote:
Do,
If
you want to do this without using mapscript, you can pull
the gradient calculation as an attribute from your data
table.
ALTER TABLE mytable ADD COLUMN gradient_color
VARCHAR;
UPTATE mytable SET gradient_color = floor(gradient *
255)::text || ' 0 0';
Cheers
Mtro. Carlos Ruiz
On Monday, June 23, 2014 4:59 PM, "Lime, Steve D
(MNIT)" <Steve.Lime at state.mn.us>
wrote:
You can compute a color
string using PostgreSQL string functions:
SELECT percentage ||
‘ 0 0’ AS color FROM …
Steve
[mailto:mapserver-users-bounces at lists.osgeo.org]
On Behalf Of Do Wi
Sent: Sunday, June 22, 2014 3:50 PM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] color attribute
question
hi!
i have this
scenario:
i have a column in my
postgis table which contains a double representing a
percentage.
i want to color my
polygons in a gradient fashion based on that
number.
the docs states three
ways to specify color:
1. three [1-255]
numbers
2. hex
string
3.
[attribute]
but the attribute must
be a string by itself in the same format as options 1 or
2.
how can i achieve
something like
COLOR [percentage]*255 0
0
or
COLOR [percentage] 0
0
if percentageis already
0..255
for a red gradient for
example?
thanks
allot!
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
