[mapserver-users] Installing MapServer on Windows
Jeff McKenna
jmckenna at gatewaygeomatics.com
Sat Jun 28 01:43:55 PDT 2014
On IIS systems I often have to set the PROJ_LIB system environment
variable, to the location of the 'epsg' file, and then reboot the
server, such as:
Variable: PROJ_LIB
Value: C:\ms4w\proj\nad
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 2014-06-27, 11:11 PM, Kris Spring wrote:
> Howdy,
> I've got a dump of a NASA World Wind map database and I'm trying to
> setup a standalone map environment. Not sure if anyone has done this
> before, but the documentation isn't exactly up to date or complete.
> Here's my setup:
> Windows 7 64-bit
> MapServer 6.4.1
> I've installed MapServer and have modified IIS7 so that I can run
> mapserv.exe. The NASA World Wind comes with a .map file and basically
> everything that I need. When I try to bring up the .map file I get the
> following error:
> Sample url:
> localhost/mapserver/mapserv.exe?map=<path>/nasaww.map&request=getacpabilities&service=wms
> msProcessProjection(): Projection library error. proj error "Permission
> denied" for "init=epsg:4326"
> I've tried looking at permissions and opening everything up just to see
> if I can get it to work, but no dice. Anyone have any ideas?
> Thanks,
> Kris
