[mapserver-users] ows_http_max_age
Richard W. White
rwhite at edrnet.com
Mon Jun 30 18:01:51 PDT 2014
I'm having an issue setting the cache-control max-age parameter in my
Mapfile. I'm not using MapCache.
Using fiddler, I'm seeing that the max-age is being set in the header.
However, there is an warning message that because the last modified
parameter isn't also set, the max-age test won't be honored.
I'm not seeing anything in either MapServer or in Apache that will explains
this.
Thanks, Richard
View this message in context: http://osgeo-org.1560.x6.nabble.com/ows-http-max-age-tp5148901.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
