[mapserver-users] shp2img working, mapserv not
cjolson
cjolson64 at gmail.com
Mon Jun 30 23:28:23 PDT 2014
Hi all,
thanks in advance for any help on this. I've been trying to create a layer
of tiled geotiffs. I made a .shp file index with gdaltindex and am
referencing this in the layer. When I run shp2img locally I get a correct
.png image, but when I try to call mapserv from a web browser with the url:
http://192.168.1.200/cgi-bin/mapserv?map=/var/www/html/topex/srtm.map&layer=SRTM30_plus&mode=map
I get the following error:
msDrawMap(): Image handling error. Failed to draw layer named 'SRTM30_Plus'.
msDrawRasterLayerLow(): Unable to access file. Corrupt, empty or missing
file '/var/www/html/topex/../../data/SRTM/srtm30_plus_geotiff/topoN0E0.tiff'
for layer 'SRTM30_Plus'.
I have the same results trying to look at each of the GeoTIFFs individually.
Here is the mapfile I'm working with:
MAP
NAME Global_Grid
SIZE 1200 600
UNITS dd
EXTENT -180 -84 180 84
CONFIG "MS_ERRORFILE" "/tmp/ms_error.txt"
DEBUG 5
LAYER
NAME SRTM30_Plus
STATUS DEFAULT
TYPE RASTER
TILEINDEX "../../data/SRTM/srtm_index.shp"
END
END
I suspect it may be a permissions problem with the apache server, but I am
currently at a loss. Any help would be appreciated.
View this message in context: http://osgeo-org.1560.x6.nabble.com/shp2img-working-mapserv-not-tp5148920.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
More information about the MapServer-users
