[mapserver-users] Force label rendering without overlapping
aborruso
aborruso at gmail.com
Tue Mar 4 08:09:41 PST 2014
Hi all,
I would like to render all the label of a polygon. I know that the only
solution I have for my geometries is to use LEADER.
But I have some problems. If I do not set FORCE TRUE, the labels overlap
each other and I have no LEADER line. In the below image two results I have
with Mapserver, and a sketch of my goal.
Is there a way to have a greater number of labels and leader lines?
Below my layer setting.
I'm using MapServer version 6.4.1 with GDAL 1.10.1, released 2013/08/26.
Thank you very much,
Andrea
<http://osgeo-org.1560.x6.nabble.com/file/n5107466/2014-03-04_16h57_04.png>
LAYER
CLASSITEM "Status"
CONNECTION "mappa_di_base.shp"
CONNECTIONTYPE OGR
FILTER ('[Status]' eq '3' OR '[Status]' eq '2' OR '[Status]' eq '1')
LABELITEM "ID"
METADATA
"coordsys_name" "Popular Visualisation CRS / Mercator (deprecated)"
END # METADATA
NAME "geo_32633"
STATUS ON
TEMPLATE "query"
TILEITEM "location"
TYPE POLYGON
UNITS METERS
CLASS
NAME "Note"
LABEL
ANTIALIAS TRUE
FONT "arial"
SIZE 10
BUFFER 10
OFFSET 0 0
POSITION AUTO
SHADOWCOLOR 255 255 255
SHADOWSIZE 0 0
TYPE TRUETYPE
END # LABEL
LEADER
MAXDISTANCE 5000
STYLE
COLOR 0 255 255
WIDTH 2
END # STYLE
END # LEADER
STYLE
ANTIALIAS TRUE
BACKGROUNDCOLOR 255 0 128
COLOR 255 0 128
OUTLINECOLOR 50 50 50
SIZE 0
WIDTH 2
END # STYLE
TEMPLATE "query"
TITLE ""
END # CLASS
END # LAYER
View this message in context: http://osgeo-org.1560.x6.nabble.com/Force-label-rendering-without-overlapping-tp5107466.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
