[mapserver-users] JSON template
Richard Greenwood
richard.greenwood at gmail.com
Tue Mar 11 17:03:03 PDT 2014
The JSON template has *[feature trimlast=","]* for a single layer that may
return multiple records, but I don't see that functionality for the whole
JSON object. For example if I have two layers but only one returns results
I end up with a trailing comma and invalid JSON.
// MapServer template
[resultset layer=layer1]
[/feature]
}, // might need to trim this comma if layer below doesn't return result
[/resultset]
[resultset layer=layer2]
[/feature]
} // no comma here because we think it's last result object
[/resultset]
I can work around it by putting a comma and empty object at the end:
which is the way I've done it when writing JSON with standard templates,
but that's sort of inconsistent with the [feature trimlast=","] option.
Am I missing anything? Should I file a feature enhancement request?
And trimlast="," does seem to need to require double, not single quotes.
Thanks,
Rich
Richard Greenwood
www.greenwoodmap.com
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140311/926915cf/attachment.html>
