[mapserver-users] join shp with csv
Lars Lingner
gislars+list at googlemail.com
Thu Mar 13 05:17:09 PDT 2014
Hi Jörg,
On 13.03.2014 11:07, Jörg Thomsen wrote:
> tried upper und lower cases for column-names
> funny: the only output in errorlog (level5) is:
>> [Thu Mar 13 10:48:52 2014].209278 msSearchDiskTree(): Search returned no results. Unable to open spatial index for /home/user/data/mapserverIIWS/./shapes_join/places_join.qix. In most cases you can safely ignore this message, otherwise check file names and permissions.
>> [Thu Mar 13 10:48:52 2014].209678 freeLayer(): freeing layer at 0x9451cd8.
> 'Search returned no results.' but there are results....
> $ ogrinfo join.csv lookup -summary
> INFO: Open of `join.csv'
> using driver `CSV' successful.
> FAILURE: Couldn't fetch requested layer lookup!
I don't have a working example anymore. But I can remember I used a vrt
[1] for processing CSV files. Here is a snipped I used working with toll
data [2]:
<OGRVRTDataSource>
<OGRVRTLayer name="mautdaten">
<SrcDataSource>mautdaten.csv</SrcDataSource>
<GeometryType>wkbPoint</GeometryType>
<LayerSRS>WGS84</LayerSRS>
<GeometryField encoding="PointFromColumns" x="lon" y="lat"/>
</OGRVRTLayer>
</OGRVRTDataSource>
Lars
[1] http://www.gdal.org/ogr/drv_vrt.html
[2] http://wiki.openstreetmap.org/wiki/Mautdaten
