[mapserver-users] Migrating from MS4W to GISInternals
Tamas Szekeres
szekerest at gmail.com
Sat Mar 15 12:02:29 PDT 2014
Mapserver is installed on the default website under the mapserver node (see
the IIS configuration tool for the details). The corresponding URL should
be:
http://localhost/mapserver/mapserv.exe?mode=map&...
Best regards,
Tamas
2014-03-15 19:44 GMT+01:00 EVANS, JAMES R GS-13 USAF ACC 84 RADES/SCZE <
james.evans.4 at us.af.mil>:
> It will be tomorrow before I can check to see if that fixes the problem.
> I'll let you know.
> At home, the installation did run on my Win7-32bit Windows machine.
> mapserv -v returns the version info. I"m still having trouble figuring
> out what the correct URL is for hitting the mapserver. Nothing I've tried
> seems to work. Any suggestions on that?
> Thanks,
> James
> *From:* mapserver-users-bounces at lists.osgeo.org [
> mapserver-users-bounces at lists.osgeo.org] on behalf of Tamas Szekeres [
> szekerest at gmail.com]
> *Sent:* Saturday, March 15, 2014 11:48 AM
> *To:* EVANS, JAMES R GS-13 USAF ACC 84 RADES/SCZE
> *Cc:* mapserver-users at lists.osgeo.org
> *Subject:* Re: [mapserver-users] Migrating from MS4W to GISInternals
> Reading through several discussions about this problem, it looks like
> you'd require to install the IIS6 management compatibility option in IIS7.
> See the following document for the details:
> http://docs.liebsoft.com/Account-Reset-Console-Installation-Guide/4469.htm
> May be a more recent wix package can fix this installation problem more
> conveniently.
> Best regards,
> Tamas
> 2014-03-15 18:28 GMT+01:00 EVANS, JAMES R GS-13 USAF ACC 84 RADES/SCZE <
>> Hi Tomas,
>> The error says "Cannot Connect to IIS" with a code of -2147221164.
>> Thanks,
>> James
>> *From:* Tamas Szekeres [szekerest at gmail.com]
>> *Sent:* Saturday, March 15, 2014 11:17 AM
>> James,
>> Do you have a specific error code or message?
>> Tamas
>> 2014-03-15 17:40 GMT+01:00 EVANS, JAMES R GS-13 USAF ACC 84 RADES/SCZE <
>>> Hi,
>>> I've been trying to get the .msi installation package from GISInternals
>>> to install on my Win7-64Bit machine at work. IIS 7 is installed, and the
>>> machine is on a domain. I’m an admin on the local machine, but not on the
>>> domain. The package works just fine on my Win7-32bit machine at home. I'm
>>> not an expert on IIS, so I'm really not sure what the problem is. It's
>>> probably some sort of permissions problem. I've given my login, and
>>> IIS_USRS full control over the default website. The install fails at a
>>> point where I see a message saying "Starting IIS Metabase Transaction".
>>> Any suggestions on where to look would be appreciated.
>>> Thanks,
>>> James
>>> mapserver-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140315/5d47f129/attachment.html>
