[mapserver-users] Migrating from MS4W to GISInternals
EVANS, JAMES R GS-13 USAF ACC 84 RADES/SCZE
james.evans.4 at us.af.mil
Mon Mar 17 06:30:04 PDT 2014
Hi Tamas,
Two other quick questions. Under my MS4W version, I was getting transparency for the following layer:
LAYER
NAME "States"
METADATA
"wms_title" "States"
"wms_name" "States"
"wms_extent" "-180 -90 180 90"
"wms_srs" "ESPG:4326"
"wms_style" "Default"
END
GROUP Features
STATUS ON
TYPE POLYGON
DATA "d:\\MapData\\states\\ne_10m_admin_1_states_provinces_shp"
LABELITEM "name"
CLASS
STYLE
#COLOR 246 241 223
OUTLINECOLOR 0 0 250
END
LABEL
COLOR 255 0 0
POSITION AUTO
MAXSCALEDENOM 40000000
END
END
MAXSCALEDENOM 1000000000
End
Under this version, it's not transparent. It has a black background. This is the same with another vector set. Any idea why that would change?
Also, I don't seem to be able to access the gdal minidrivers. It's probably a permission problem. Here's my layer:
LAYER
NAME "GNC_Tiled"
DATA "d:\\mapdata\\GNC.xml"
GROUP Tiled
TYPE RASTER
STATUS ON
END
The error I get says that it cannot access the file GNC.xml. I've tried putting the file in the mapserver directory, and hard coding the path to the file. Nothing seems to work. Any ideas?
Thanks,
James
Sent: Monday, March 17, 2014 2:19 AM
To: EVANS, JAMES R GS-13 USAF ACC 84 RADES/SCZE
Cc: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Migrating from MS4W to GISInternals
szip.dll is also required to copy into the mapserver directory.
Best regards,
Tamas
2014-03-17 5:43 GMT+01:00 EVANS, JAMES R GS-13 USAF ACC 84 RADES/SCZE <james.evans.4 at us.af.mil<mailto:james.evans.4 at us.af.mil>>:
Hi Tamas,
Still no luck getting it working. hdf5.dll, hdf5_hl.dll, and hdfdll.dll were not in the mapsrver directtory. I copied them over. Still no luck displaying the raster data. There several other dlls in the bin directory of the zip that are not in the mapserver directory. THey include:
freexl.dll
ftgl.dll
libecwj2.dll
libtiff.dll
lti_dsdk_9.0.dll
lti_lidar_dsdk_1.1.dll
mfhdfdll.dll
msplugin_mssql2008.dll
msplugin_oracle.dll
msvcp100.dll
msvcr100.dll
NCSEcw.dll
szip.dll
tbb.dll
xdrdll.dll
Should any of these also be copied over to the mapserver directory?
Thanks,
James
From: Tamas Szekeres [szekerest at gmail.com<mailto:szekerest at gmail.com>]
Sent: Sunday, March 16, 2014 6:52 AM
Cc: mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
I suspect hdf5.dll and hdf5_hl.dll is still missing on your target directory. Copy those files from the .zip package mentioned before.
Tamas
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140317/1b8e907e/attachment.html>
